Early 1970 914 original barn find..., Going to see it Friday, owner finally wants to sell it... |
oakdalecurtis |
May 24 2021, 05:32 AM
Oakdalecurtis Group: Members Posts: 1,348 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
Ok Brain Trust! I am going with another 914 owner to Sonora, Ca this Friday to look at a 1970 barn find. This 2nd owner said the car has been in his barn for 20 years, that it ran when went in, and has been rolled about but never started over the years. VIN # is 4702902635, which I believe would make it the 2,635th 914 built in the first year of production, 1970. The odometer says a little over 60K miles. We will check the engine number, but have no reason to believe it is not all original. He says that other than the obvious cosmetic issues outside, there is no bondo that he could find (magnet checked) and no chassis rust (I know, we've all heard that before. We'll look Friday as best we can, hell hole, trunks, etc, but won't be able to remove the rockers).
Question: IF we can roll the car, AND the brakes are not seized, AND the engine rotates in gear, AND I bring a battery and fire extinguisher, would it be ok to hook up the battery, turn the ignition just to the "on" position and see if the gauges come to life? IF they do and that checks out positively, what about trying to start it? I know the fuel is probably crap, and the fuel lines COULD leak, but if it all seems good up to that point, what about a test start up? I will try to find the engine number on the top of the engine. Besides lots of photos and checking the obvious areas for rust, what else might we want to know about? It looks like it has the original standard VW steelie wheels and caps, correct for these early 914's. Shouldn't it have a 1.7 label on the back along with the 914 label? I will ask him for all records that he has also. I convinced the owner to let the car go to someone who wants a project car. I told him I would be willing to post all photos and info that I get there on this site and see if any members here would like to BAT and get his project car. My GUESS at this point, with this info, is I would recommend a price around $3500. Any further thoughts or comments before my Friday visit? Think I'm close on a price recommendation, with what we know so far? |
Superhawk996 |
May 24 2021, 07:12 AM
914 Guru Group: Members Posts: 6,637 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
what about trying to start it? I know the fuel is probably crap, and the fuel lines COULD leak, but if it all seems good up to that point, what about a test start up? Trying to start an engine that has been sitting for 20 years is a bad plan. 1) Horizontal boxer engines don't store well. Usually end up with corrosion and pitting on bottom of the cylinders. 2) At a bare minimum you want to pre-treat cylinders with oil and/or penetrating oil before a 1st start to avoid breaking rings. Oil in the crank is probably garbage and won't do any favors for bearings even if it tried to start. Clutch probably has a 50/50 chance of being stuck to the flywheel. Whole host of other "what if" or "could" scenarios very few of which are in your favor to have it just simply start. 3) Even if it does start the engine still probably run very rough and needs to be rebuilt due to #1 or simply that it got put in "storage" because it wasn't running right to start with. 4) You're just going to suck in bad fuel and/or rust from the tank making matters worse for injectors and/or carbs. 5) If it does sputter or even cough, the seller now thinks its worth $1000 more even though it still likely needs a complete engine rebuild. It is what it is. May be a nice car for restoration but as it sits a poorly running engine means very little to actual value of the car. |
Lo-Fi Version | Time is now: 6th January 2025 - 07:36 PM |
