> Eyebrow grommet installation, Ended up using 030 mig wire
john77
post Jun 2 2021, 03:36 PM
I just ordered a set of 914rubber eyebrow grommets... is there a trick or tool for installing these things without a) piercing them with a screwdriver, or b) screaming words that young children shouldn't hear?
Also, how on earth do you get enough leverage to install the one that's inside the fender?
ejm
post Jun 4 2021, 05:53 AM
I can see the light at the end of the tunnel
The factory designed the grommets to be installed in the eyebrow with the pointed ends facing out. The eyebrow is then slid into place with tension holding the pointed end into the body panel. This allowed the eyebrow to push down out of place if something got in the way of a closing headlight. All the aftermarket grommets I've seen are too small to be used as the factory intended. Someone should make an accurate reproduction of this NLA part.
914e
post Jun 4 2021, 09:47 AM
QUOTE(ejm @ Jun 4 2021, 04:53 AM) *
That is the way mine where installed, and the same way I put them back in. The replacements are loose and popped out once or twice when I installed the eyebrows.
john77   Eyebrow grommet installation   Jun 2 2021, 03:36 PM
roblav1   Palmolive. Marge, you're soaking in it! F...   Jun 2 2021, 03:46 PM
john77   @[url=http://www.914world.com/bbs2/index.php?showu...   Jun 3 2021, 01:42 PM
bbrock   "Sorry, swearing is mandatory but piercing ...   Jun 3 2021, 01:47 PM
john77   Right? It never would have dawned on me, but I can...   Jun 3 2021, 01:50 PM
bbrock   Sorry, swearing is mandatory but piercing is not. ...   Jun 2 2021, 04:53 PM
bdstone914   Wrap some dental floss in the groove of the gromet...   Jun 2 2021, 04:57 PM
Al Meredith   K-Y is the slickest   Jun 3 2021, 03:40 PM
windforfun   What are the eyebrow grommets for?   Jun 3 2021, 04:30 PM
john77   They attach the eyebrows to the car - two through ...   Jun 3 2021, 05:06 PM
ClayPerrine   They attach the eyebrows to the car - two through...   Jun 4 2021, 05:59 AM
partwerks   I warmed the rubber up a bit with a heat gun to ma...   Jun 3 2021, 05:57 PM
windforfun   Stupid question here - what's an eyebrow? :h...   Jun 3 2021, 06:04 PM
bbrock   Stupid question here - what's an eyebrow? :...   Jun 3 2021, 06:41 PM
Mikey914   The metal plate between the eye (headlight) and th...   Jun 3 2021, 06:09 PM
PanelBilly   Always use the water based lube. The silicone stuf...   Jun 3 2021, 07:28 PM
ejm   The factory designed the grommets to be installed ...   Jun 4 2021, 05:53 AM
914e   The factory designed the grommets to be installed...   Jun 4 2021, 09:47 AM
Root_Werks   A few have already pointed out the obvious: Reason...   Jun 4 2021, 11:26 AM
john77   Wow, who knew there was so much I didn’t know ab...   Jun 5 2021, 10:44 AM
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 5th February 2025 - 05:48 AM
