Fog light hardware?, The bracket to the body |
NARP74 |
Jun 5 2021, 03:56 PM
Senior Member Group: Members Posts: 1,300 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
I need a pic of the body mount hardware for the lights, the bracket to the car. The inside looks like a captive nut or something. You can see it under the headlight from the front trunk. Tough angle to get a pic, but it would really be appreciated.
My car, 74 2.0 must have been wrecked at some point and had another front grafted on. It might have been an older one so they used sheet metal screws for mounting the lights that won't hold anymore. PET, pg 285, seems to say it uses a M10 x 16 pan head screw, some sort of spring washer but does not mention the nut. I may just have to hold one back there manually and hope it holds, maybe use a nylock. Not trying to make it perfect, just better than it is now. Thanks in advance for the help. |
L-Jet914 |
Jun 5 2021, 09:45 PM
Member Group: Members Posts: 290 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
I need a pic of the body mount hardware for the lights, the bracket to the car. The inside looks like a captive nut or something. You can see it under the headlight from the front trunk. Tough angle to get a pic, but it would really be appreciated. My car, 74 2.0 must have been wrecked at some point and had another front grafted on. It might have been an older one so they used sheet metal screws for mounting the lights that won't hold anymore. PET, pg 285, seems to say it uses a M10 x 16 pan head screw, some sort of spring washer but does not mention the nut. I may just have to hold one back there manually and hope it holds, maybe use a nylock. Not trying to make it perfect, just better than it is now. Thanks in advance for the help. The washers used on the bolt side are a spring washer. I recently installed a set of Hella 118 Euro driving lights/fog lights on my 74 1.8L. I used all new hardware. Stainless steel allen head bolts M10x16 with new wave washers into the captive nuts. I purchased a wave washer kit from amazon with different sized wave washers grant it I didn't need all of them, but now I have extras. |
Lo-Fi Version | Time is now: 27th December 2024 - 11:33 PM |
