> Rear Sway bar install, Trying to figure out how everything goes together
roundtwo
post Jun 13 2021, 06:48 PM
Trying to get prepped for all my welding needs. Id like to Pre-fit the rear sway bar so I can determine exactly we’re to mount the bushing mount backing plates. I want to be sure they’re perpendicular to the sway bar in just the right spot
1. See first pick. Do I install the bushings in the drop links first and then install the ball ends? Or, do I install the ball cups on the balls and then have them pressed into the drop links? Any tips on how to get these hard bushings into the drop links?
2. Do I simply replace the new shock base metal rod labeled #1 with #2. See second pic
I’ve read the rear sway bar mounts instructions on the Pelican Parts web site. Very helpful- He just doesn’t cover the actual sway bar assembly. Bar is 16mm. Installing on a 1970.
Many thanks.
bkrantz
post Jun 13 2021, 07:38 PM
I put the bushings into the drop links first (used my hydraulic press), and then squeezed the links onto the trailing arms and sway bars, with a large clamp.
- Lo-Fi Version Time is now: 31st October 2024 - 08:24 PM
