Rear Sway bar install, Trying to figure out how everything goes together |
roundtwo |
Jun 13 2021, 06:48 PM
Member Group: Members Posts: 302 Joined: 9-February 20 From: Petaluma, CA Member No.: 23,905 Region Association: Central California |
Trying to get prepped for all my welding needs. Id like to Pre-fit the rear sway bar so I can determine exactly we’re to mount the bushing mount backing plates. I want to be sure they’re perpendicular to the sway bar in just the right spot
1. See first pick. Do I install the bushings in the drop links first and then install the ball ends? Or, do I install the ball cups on the balls and then have them pressed into the drop links? Any tips on how to get these hard bushings into the drop links? 2. Do I simply replace the new shock base metal rod labeled #1 with #2. See second pic I’ve read the rear sway bar mounts instructions on the Pelican Parts web site. Very helpful- He just doesn’t cover the actual sway bar assembly. Bar is 16mm. Installing on a 1970. Many thanks. |
NARP74 |
Jun 14 2021, 12:41 PM
Senior Member Group: Members Posts: 1,238 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
I just went through this, mine had the mounting brackets which made it easier. I did everything on the car which made it harder. Do as much on the bench as possible. I used boiling water and then a little liquid soap and pressed them on. I removed the muffler to give me as much room as possible. Good luck...
Lo-Fi Version | Time is now: 31st October 2024 - 08:24 PM |
