sjhenry1075 |
Member ![]() ![]() Group: Members Posts: 269 Joined: 22-July 12 From: Stevensville, MD Member No.: 14,709 Region Association: North East States ![]() ![]() |
Hey everyone, please excuse my lack of knowledge on this subject, but I have a question regarding air / fuel mixture adjustment on my 71 1.7 with stock D-jet. I posted this question on Facebook but wanted to try here as well.
Back story: my car will only idle and drive when both vacuum lines are disconnected from the distributor. When connected (I used a diagram found on 914world so I know they aren't flipped) the car barely idles when cold or warm, and it is almost undriveable; it surges, bucks, and hesitates. If I remove both vacuum lines from the distributor it idles and runs great. From what I understand from the replies on FaceBook, this could be an air/fuel mixture issue, but how is that adjusted with for the 71? Is there a certain procedure for this? Thanks in Advance for any assistance you can provide! For those going to PA for the Northeast gathering, I'm looking forward to meeting you! |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,645 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
another thing that can make the car run rich is a failing Cylinder Head Temp sensor
you can check them with an OHM meter. pulling if from the engine isn't hard.. involves a modified 13mm deep socket. and allows you to put the sensor into the freezer or boiling water for the full range testing. |
JamesM |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,935 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region ![]() |
another thing that can make the car run rich is a failing Cylinder Head Temp sensor you can check them with an OHM meter. pulling if from the engine isn't hard.. involves a modified 13mm deep socket. and allows you to put the sensor into the freezer or boiling water for the full range testing. (IMG:style_emoticons/default/agree.gif) This would be the next thing I would look at after ruling out any timing/dizzy issues. Only 2 things really have a significant impact on the mixture, the MPS and the CHT sensor. Bad MPS generally causes an overly rich condition. (unless there is a parts missmatch) CHTs can fail multiple ways, broken circuit will cause extreme richening, shorted to ground will cause things to go lean, changes to the resistance curve can cause either. |
Lo-Fi Version | Time is now: 30th June 2024 - 11:18 AM |
