Oil pressure switch / sensor, removal |
EJP914 |
Jul 5 2021, 05:40 PM
Member Group: Members Posts: 260 Joined: 14-June 03 From: Monroeville, PA Member No.: 821 |
Is the rubber boot that sits on top and round the sensor just lift off? Looks like the edge/lip on it is just sitting on top of the engine sheet metal.
Also, does it take 24 mm deep well socket to remove the sensor? Thanks EJP914 |
scottthephotog |
Jul 5 2021, 08:02 PM
Member Group: Members Posts: 187 Joined: 20-November 18 From: Euless, TX Member No.: 22,667 Region Association: Southwest Region |
The rubber boot should come off relatively easily. As far as the sender, I went through about 4 different 24mm sockets (regular and deep) before I found one that fit nicely around the distributor. Most deep sockets will interfere with the distributor. Removing the distributor makes it much simpler to remove the sender.
Lo-Fi Version | Time is now: 26th June 2024 - 08:54 AM |
