correct value for warm CHT reading (ohms) |
brant |
Jul 7 2021, 09:14 AM
914 Wizard Group: Members Posts: 11,824 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
so my CHT reading was 76 ohms - hot (at 180F oil temp)
I'm reading 2 different things.. on the Brad anders site one saying that a warm reading should be below 100 ohms but then the table shows this: for 210F Sensor Temp = 39 deg. F Temp = 61 deg. F Temp = 210 deg F 0 280 130 003 6.10 K ohms 2.94 K ohms 199.3 ohms 0 280 130 012 NA 2.85 K ohms 191.2 ohms 0 280 130 017 3.63 K ohms 1.74 K ohms 124.7 ohms I'd love some input from Djet folks about what numbers you see on a warm motor? brant |
brant |
Jul 7 2021, 02:46 PM
I'm in agreement with everything you said.
I was re-reading anders last night... and he did say occasionally the CHT will fail with a ground and go 30% lean.... so that was the idea I was chasing. but 76ohms hot sounds like it could be within tolerance. I checked timing, fuel pressure, MPH-vacuum, and CHT(hot/cold) last night and everything was perfect. I thought about bumping my fuel pressure as one solution. But decided I needed to see the AFR's before I made any changes. In the past I had tuned this MPS and the AFR's were spot on. I even tuned a 2nd MPS at the same time, and may need to dig that one out of storage to do some more testing unfortunately... I had a few beers in my wrenching last night.. so put off road testing until tonight... should know more soon and possibly, I'm chasing nothing... other than a plug that as you pointed out... is hard or inaccurate to read anyways. |
Lo-Fi Version | Time is now: 28th December 2024 - 02:49 AM |
