Back up light switch on tranny, Maybe a dumb question |
burlybryan |
Jul 8 2021, 08:05 AM
Member Group: Members Posts: 118 Joined: 25-May 20 From: Saint Paul Member No.: 24,311 Region Association: None |
I have no reverse/backup lights. Jumpering the wires on the tranny mounted switch gets them to come on, so I figure the wiring is ok and the switch is flaky. I have no knowledge about the internals of our trannys, so before I replace it I wanted to verify if the switch is immersed in fluid or dry. If wet, I'd just plan a gear oil change as part of the process.
Thanks for any insight. Bryan |
Shivers |
Jul 8 2021, 08:16 AM
Senior Member Group: Members Posts: 2,825 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
it sits right around the same height as the filler plug on the other side. Put a pan under it, have everything clean, screw out old part then screw in new part. Then if you did lose a bit add it in the filler plug if the amount makes you uncomfortable.
Lo-Fi Version | Time is now: 27th December 2024 - 04:01 PM |
