> Coil Failing?, New plug wires and now it runs rough?
Neptune
post Jul 8 2021, 08:04 AM
So I Have a 70 1.7L
It was stored for 4+ years
Fuel has been replaced with fresh
Had a miss so decided to replace the standard maintenance ignition components. Replaced the spark plugs and found hole 1 was "wet" and carbon-ed up. Ran much better with new plugs. Continued to replace cap and rotor, because I had the new parts and they were worn. Dizzy has the OG Pertronix Ignitor setup in it.
Got new plug wires yesterday, put them on and now it runs like complete crap! I checked all the connections and they are all seated as they should be and its just garbage. So from what I can tell the issue isn't just in one hole and that brings me to suspecting the coil. It is old, I've had the car since '93 and I've never replaced it.
Open to all thoughts and suggestions...
Shivers
post Jul 8 2021, 08:25 AM
"Got new plug wires yesterday, put them on and now it runs like complete crap!"
Make sure of the firing order, it is easy to have two wires flipped and not notice It will run but it will run like crap.
Check the easy and free stuff first before throwing money at it.
Neptune
post Jul 8 2021, 08:30 AM
QUOTE(Shivers @ Jul 8 2021, 08:25 AM) *
Ya I learned a long time ago to change plug wires 1 by 1 following the wire, so I know that isn't it. The missing/rough firing isn't constant, it is intermittent and swapped wires would be a constant rough running motor. Good idea though! Thanx.
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 28th December 2024 - 01:04 AM
