Coil Failing?, New plug wires and now it runs rough? |
Neptune |
Jul 8 2021, 08:04 AM
Newbie Group: Members Posts: 8 Joined: 29-June 21 From: Montana Member No.: 25,675 Region Association: Rocky Mountains |
So I Have a 70 1.7L
It was stored for 4+ years Fuel has been replaced with fresh Had a miss so decided to replace the standard maintenance ignition components. Replaced the spark plugs and found hole 1 was "wet" and carbon-ed up. Ran much better with new plugs. Continued to replace cap and rotor, because I had the new parts and they were worn. Dizzy has the OG Pertronix Ignitor setup in it. Got new plug wires yesterday, put them on and now it runs like complete crap! I checked all the connections and they are all seated as they should be and its just garbage. So from what I can tell the issue isn't just in one hole and that brings me to suspecting the coil. It is old, I've had the car since '93 and I've never replaced it. Open to all thoughts and suggestions... |
Shivers |
Jul 8 2021, 08:58 AM
Senior Member Group: Members Posts: 2,827 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Usually when they are going bad, and not dead, they will start up cold ok. But not long at all the coil body will start to heat up and the engine will start to miss. Depending on how bad it is will depend on how long you will be able to touch the coil @Neptune
Lo-Fi Version | Time is now: 28th December 2024 - 12:13 AM |
