MPS Case Leaks...., Ideas on how to seal? |
tvdinnerbythepool |
Jul 10 2021, 01:10 PM
Member Group: Members Posts: 310 Joined: 24-July 18 From: Olympia, WA Member No.: 22,336 Region Association: Pacific Northwest |
Hey all,
I rebuilt my MPS last year with the tangerine kit. I fought getting the case to stop leaking after the rebuild as I've seen a few others have this issue too. I used grease on the gasket which seemed to do the trick...that lasted about a year and now yet again I have the case leak. Anyone figure out a permeant solution to this? I am wondering if I can RTV or something to seal the bastard shut. In theory it won't need to be disassembled for a long time. Let me know what you guys think! -R p.s. I've checked the vacuum and hoses to make sure they aren't the culprit. I also checked a used MPS I bought on ebay with the same vacuum setup and it holds steady at 15". Definitely the case 1/2 seal. |
914_teener |
Jul 10 2021, 01:29 PM
914 Guru Group: Members Posts: 5,250 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Are you running a properly working Decell Valve with your D-jet setup?
Lo-Fi Version | Time is now: 28th December 2024 - 02:30 AM |
