914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,088 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
I bought a z-green 74 and am in the process of sorting it out to run. I am replacing everything that is missing and not correct. I started sorting out the fuel injection and found the fuel pump moved to the front of the car with a piece of zip cord run through the tunnel from the rear to power the pump. All of this was mounted on the front suspension pan cover.
Wonder why this door rotted out? It is completely covered with 1/2 " carpet pad. Every surface had pad glued down including the bottom of the door where the drain holes were. Both door were done like this. Back wall had same carpet pad behind the molded wall. Attached image(s) ![]() ![]() ![]() ![]() |
volksaddict |
Newbie ![]() Group: Members Posts: 28 Joined: 29-January 11 From: southwest Member No.: 12,645 Region Association: Southwest Region ![]() |
PO left me a couple spare Berus (IMG:style_emoticons/default/shades.gif) Note the masking tape on the installed plugs, guess He didn't have a spark plug socket.
Lo-Fi Version | Time is now: 11th March 2025 - 01:26 PM |
