> oil pressure switch, wiring help needed!
mobymutt
post Jul 11 2021, 08:11 PM
I just swapped out my 1.8L for a 1.7L (so I could rebuild the 1.8L), and I can't find the wire that goes to the pressure switch.
I've got carbs, so the wire harnesses have a zillion unused wires. But I thought there would be a wire with a dangling connector somewhere nearby... apparently not.
The car is a '74. From the wiring diagram, it looks like the wire should be green with red stripes, but I can't find that either.
Can anybody tell me how I might go about finding the correct wire to hook up? Maybe the physical location of the wire run to start? Or where it comes from, or what other wires it would be with?
Any help is appreciated, thank you!
post Jul 11 2021, 11:15 PM
IIRC, that wire is attached to the rear of the engine case and goes towards the right side then stops close to the edge of the engine case.The connecting wire is below the battery and may have a plastic cover over the female spade.
- Lo-Fi Version Time is now: 27th December 2024 - 03:56 PM
