oil pressure switch, wiring help needed! |
mobymutt |
Jul 11 2021, 08:11 PM
Senior Member Group: Members Posts: 553 Joined: 16-December 13 From: Kingston, Ontario, Canada Member No.: 16,770 Region Association: Canada |
I just swapped out my 1.8L for a 1.7L (so I could rebuild the 1.8L), and I can't find the wire that goes to the pressure switch.
I've got carbs, so the wire harnesses have a zillion unused wires. But I thought there would be a wire with a dangling connector somewhere nearby... apparently not. The car is a '74. From the wiring diagram, it looks like the wire should be green with red stripes, but I can't find that either. Can anybody tell me how I might go about finding the correct wire to hook up? Maybe the physical location of the wire run to start? Or where it comes from, or what other wires it would be with? Any help is appreciated, thank you! |
iankarr |
Jul 12 2021, 12:30 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,526 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
I'm away from the garage, but pretty sure oil pressure switch wire is part of the ignition harness, which connects via the large plug on the relay board. The oil temp wire sprouts from the main harness near the battery tray.
Lo-Fi Version | Time is now: 27th December 2024 - 03:32 PM |
