Another fuel filter question - 1.7, After multiple searches |
jrmdir |
Jul 12 2021, 11:43 AM
Member Group: Members Posts: 224 Joined: 13-May 21 From: Central Ohio Member No.: 25,544 Region Association: Upper MidWest |
Hello:
Most of what I'm seeing is to go with the Mahle filter that has 8mm fittings on each end: https://www.pelicanparts.com/More_Info/3111...I=5882&fs=0 But the supply line from the tank is larger (9mm?) I see that Tangerine has metal tube reduction adaptors but what are people doing otherwise to fit the larger rubber fuel lines onto this type of filter? Just crank down on the clamp? TIA. Ron |
jrmdir |
Jul 12 2021, 12:03 PM
Thanks for the quick info. I'll check with AA but wonder if something like this would work: https://www.amazon.com/Reducer-Hose-Brass-F...s/dp/B078QZ2MJC
JeffBowlsby |
Jul 12 2021, 02:27 PM
914 Wiring Harnesses Group: Members Posts: 8,781 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Thanks for the quick info. I'll check with AA but wonder if something like this would work: https://www.amazon.com/Reducer-Hose-Brass-F...s/dp/B078QZ2MJC Don't get us started on barbed fittings used in a pressurized fuel hose system. |
Lo-Fi Version | Time is now: 27th December 2024 - 08:57 PM |
