What suspension and brake parts fit a 71 and 74?, I have jumbled parts from both years. |
overmyhead |
Jul 12 2021, 02:28 PM
Newbie Group: Members Posts: 2 Joined: 12-July 21 From: Ottawa Member No.: 25,713 Region Association: None |
I bought 2 disassembled 914s from the same guy. One a 1971 1.7 and a 1974 2.0. Unfortunately they are all jumbled together.
For instance I see one front end has a stabilizer bar and the other doesn't. What else is different, brake cylinders? Steering components ? Many thanks! |
jcd914 |
Jul 12 2021, 03:19 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
The 71 frt struts, ball joints, brake rotors & brake calipers are all different from the 74. The frt control arms are interchangeable, later arm will have the brackets for sway bar links. Rear calipers are different as well, late have dual bleeders and early single bleeders but the calipers are interchangeable. I think the rubber brake hose are also different between 71 & 74 but it depends on which frt struts and which rear trailing arms are used. I have a 72 with later rear trailing arms and the hoses I ordered don't fit the bracket on the trailing arm. They function but are not secured to rear trailing arms as they should be. I'm in the middle of converting to 5 lug suspension and will replace the hoses as part of that. Jim |
Lo-Fi Version | Time is now: 27th September 2024 - 09:00 AM |
