> She lists to Port in rear, Suspension height difference
Gatornapper
post Jul 2 2021, 09:06 AM
One of the first thing I noticed when I picked up my sweet barn find 914 4 years ago was a height difference in the rear (only) - she lists to port by 1/2".
I have the service record from the local Porsche dealer that about 3,000 miles prior to my getting the car, their shop had replaced the left rear trailing arm bushings. In working extensively on my 14 for the last 4 years (my shop has a lift), I can find no cause for the 1/2" height difference in the body at the rear axle center.
Car had 60k original miles when I got it, now 63,600. I believe rear spring/shocks are original, and show no issues.
Any help would be appreciated as to cause and fix for the list.
TIA,
GN
dr914@autoatlanta.com
post Jul 2 2021, 03:45 PM
jack the front slightly from the center of the cross member to take most of the weight off of the front (do not have to lift the tires off of the ground) and see if the rear straightens out. If so the front torsion bars are out of adjustment
Gatornapper
post Jul 14 2021, 04:08 PM
George -
Thank you again for your perfect analysis. But your diagnosis was not only correct, but solved another more important problem that I did not know I had.
Setting the torsion bars to spec did indeed solve the height difference between left and right.
But it did something far more important.
Having never checked the torsion bar settings, I found both to be completely loose. This means that the bars (springs) were not in effect until after the suspension was activated by a bump in the road or a turn. There was slack on both bars!
Setting both bars to spec leveled out the car, AND tightened up the handling noticeably - to my great pleasure. It was almost as if I added sway bars! (winter project).
GN
QUOTE(dr914@autoatlanta.com @ Jul 2 2021, 03:45 PM) *
Gatornapper   She lists to Port in rear   Jul 2 2021, 09:06 AM
mepstein   Every 914 I've purchased with original shocks ...   Jul 2 2021, 09:15 AM
mrholland2   Is "port" on a car left or right? :)   Jul 2 2021, 10:35 AM
VegasRacer   Is "port" on a car left or right? :) T...   Jul 2 2021, 10:40 AM
barefoot   Previous owner (before you) must have been quite h...   Jul 2 2021, 11:59 AM
Al Meredith   Should say "aft " instead of rear. 50 ye...   Jul 2 2021, 02:34 PM
73-914   Should say "aft " instead of rear. 50 y...   Jul 2 2021, 08:34 PM
euro911   Should say "aft " instead of rear. 50 ye...   Jul 3 2021, 01:49 AM
worn   Should say "aft " instead of rear. 50 ...   Jul 4 2021, 05:49 PM
zipedadoo   Mine did the same thing. I put on new springs, new...   Jul 2 2021, 02:52 PM
dr914@autoatlanta.com   jack the front slightly from the center of the cro...   Jul 2 2021, 03:45 PM
partwerks   jack the front slightly from the center of the cr...   Jul 2 2021, 08:19 PM
zipedadoo   jack the front slightly from the center of the c...   Jul 3 2021, 07:24 AM
infraredcalvin   jack the front slightly from the center of the c...   Jul 3 2021, 08:45 AM
Gatornapper   George - Thank you so much. Will do. I haven...   Jul 3 2021, 08:18 PM
Gatornapper   George, et al - Sure nuf. Left front is 3/8...   Jul 4 2021, 07:00 PM
Gatornapper   George - Thank you again for your perfect analysi...   Jul 14 2021, 04:08 PM
Superhawk996   :agree: as a 1st step. Unless you measured the r...   Jul 2 2021, 04:05 PM
Front yard mechanic   Get a fat girl friend and drive on bumpy roads :c...   Jul 2 2021, 09:20 PM
Gatornapper   FRM - Like the girl I've had for 48 years and...   Jul 3 2021, 08:21 PM
bdstone914   @Gatornapper Hopefully it is a spring or bushing...   Jul 3 2021, 09:25 AM
sixnotfour   Depending on Ballast (you) might want to raise the...   Jul 4 2021, 07:06 PM
Gatornapper   I'm 179 lbs. Think the xtra is probably not n...   Jul 7 2021, 08:18 AM
Gatornapper   FYI - Instructions on how to correctly set the fr...   Jul 8 2021, 03:54 AM
barefoot   FYI - Instructions on how to correctly set the f...   Jul 14 2021, 04:28 PM
Gatornapper   Yes, they are a bit munged up for some reason........   Jul 15 2021, 08:08 AM
JamesM   I have the service record from the local Porsche ...   Jul 7 2021, 09:55 AM
10 User(s) are reading this topic (10 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 27th December 2024 - 06:10 PM
