Trying to contact Bob Ashlock re Tach Adapt |
DaveO90s4 |
Jul 15 2021, 04:37 AM
Member Group: Members Posts: 149 Joined: 26-April 16 From: Australia Member No.: 19,935 Region Association: None |
Hi all, as the title says.
I’ve been very happy with his tach adapt box driving my OEM distributor from my 6 cyl corvair engine. I am now replacing my carbs with fuel injection and ‘wasted spark’ ignition. So I will now have twice as many ignition signals as at present. So I think I need to change the dip switches - or maybe the tach adapt won’t be able to step down 6 cyl x 2 firings per rev per plug = ‘effectively’ 12 cylinder driving OEM 4 cyl tach. Any contact details for Bob, or solutions from those who have faced this issue, most appreciated. Thanks DaveO |
BeatNavy |
Jul 15 2021, 09:46 AM
Certified Professional Scapegoat Group: Members Posts: 2,944 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
I agree with Mark (although my experience is much more limited). I'm running Microsquirt with wasted spark. I did need to run my tach output from the ECU through a tach adapt (generously provided by Dion here), but it works like a champ.
What FI system are you going to use? |
Mark Henry |
Jul 15 2021, 10:10 AM
I agree with Mark (although my experience is much more limited). I'm running Microsquirt with wasted spark. I did need to run my tach output from the ECU through a tach adapt (generously provided by Dion here), but it works like a champ. What FI system are you going to use? Was this for a problem with the tach signal or 4 to /6 conversion? My 914 /4 with SDS and wasted spark had no tach issues. My 914/6 conversion with a 911/6 tach and MSD CDI the tach didn't work, I had to use a Tach-adapt. |
BeatNavy |
Jul 15 2021, 10:13 AM
I agree with Mark (although my experience is much more limited). I'm running Microsquirt with wasted spark. I did need to run my tach output from the ECU through a tach adapt (generously provided by Dion here), but it works like a champ. What FI system are you going to use? Was this for a problem with the tach signal or 4 to /6 conversion? My 914 /4 with SDS and wasted spark had no tach issues. My 914/6 conversion with a 911/6 tach and MSD CDI the tach didn't work, I had to use an Tach-adapt. Mark, I think it's an issue with the tach signal from Microsquirt, although I can't remember the detailed "why." It wasn't a 6 conversion. |
JamesM |
Jul 16 2021, 02:31 PM
Advanced Member Group: Members Posts: 2,023 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
I agree with Mark (although my experience is much more limited). I'm running Microsquirt with wasted spark. I did need to run my tach output from the ECU through a tach adapt (generously provided by Dion here), but it works like a champ. What FI system are you going to use? Was this for a problem with the tach signal or 4 to /6 conversion? My 914 /4 with SDS and wasted spark had no tach issues. My 914/6 conversion with a 911/6 tach and MSD CDI the tach didn't work, I had to use an Tach-adapt. Mark, I think it's an issue with the tach signal from Microsquirt, although I can't remember the detailed "why." It wasn't a 6 conversion. The non-detailed why is that the output from MS is a weaker pulse than the signal you get straight off the coil. There is a pretty easy mod you can make to the tach itself to make it compatible with modern tach signals (MS) without an adaptor but does require opening up the tach. Internally on the pulse input circuit one of the first things you encounter is a fairly large resistor. Installing a jumper across this resistor is all that is needed to make the tach compatible with the MS output. There is a secondary mod you can also do while you are in there that involves installing a capacitor (dont recall the value off the top of my head) across the tachs coil windings. This slightly dampens the tachs response and eliminates the 914 tach bounce. |
Lo-Fi Version | Time is now: 28th December 2024 - 02:52 AM |
