Windshield Washer Switch Question |
GeorgeKopf |
Jul 18 2021, 12:39 AM
Member Group: Members Posts: 189 Joined: 9-February 21 From: Princeton, NJ Member No.: 25,186 Region Association: MidAtlantic Region |
On my wiper switch there are 5 wires. Black, Brown, Green, Black/White, Black/Green
The black wire (behind the brown) mates to a brown/black wire on the main harness which isn't used. It was capped off and taped into the body of the harness right at the wiper motor. My wiring harness is a 1973. Testing for continuity between the black and the ground I get tone when I pull the wiper switch forward. I also get continuity on the black/white wire which connects to a red/black wire to the wiper motor. Can I use the black/brown to power an electric washer pump? Thanks. George |
SirAndy |
Jul 18 2021, 03:42 PM
Resident German Group: Admin Posts: 41,945 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Can I use the black/brown to power an electric washer pump? Yes, you can: http://www.914world.com/specs/tech_el_washer.php (IMG:style_emoticons/default/shades.gif) |
GeorgeKopf |
Jul 18 2021, 10:00 PM
Can I use the black/brown to power an electric washer pump? Yes, you can: http://www.914world.com/specs/tech_el_washer.php (IMG:style_emoticons/default/shades.gif) Thank you Sir Andy. I read that post and will definitely be referring back to it when the time comes. George |
Lo-Fi Version | Time is now: 28th December 2024 - 12:30 AM |
