What is the physical location of the horn relay 1973-SOLVED |
HalfMoon |
Aug 9 2013, 08:15 PM
Senior Member Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
I think the PO removed it (certainly removed the horns and the horn buttons not connected to anything).
In order to pass inspection I have to wire in horns, but I want to identify/find the relay if it's still on the car. No idea where it's supposed to be located. Doesn't appear to be located on the back of the fuse panel (according to Haynes). Soooo, where izit, lol? Thanks! |
neilbardsley |
Jul 19 2021, 01:59 PM
Newbie Group: Members Posts: 44 Joined: 11-October 20 From: England Member No.: 24,754 Region Association: Europe |
I'm trying to figure out why my horn isn't working.
The horn is good. I found the relay. Connected 30 directly to 87 and the horn sounded. Then I tested the relay and it clicked. I swapped it with another relay and the horn still didn't work. Then I tested the resistance from the horn pad brown wire to 85 and 86 but nothing? I think that the brown wire from the horn pad connects to fuse 8 and then 86? I need to check that next. However, I've no idea how to take the steering column apart |
Lo-Fi Version | Time is now: 14th January 2025 - 06:31 PM |
