> TIV 2056 in a bay window bus?, putting the engine in my 914 into my new bus maybe...
VaccaRabite
post Jul 19 2021, 06:30 AM
En Garde!
Hey folks.
I am thinking about taking the well tuned EFI 2056 out of my 914 and putting it into the '72 bay-window Westy bus I bought a few weeks ago.
A bigger TIV will go into the 914.
Though I have not mentioned my plan at the Samba - the few people that post in the bay window forum there seem to have a dim view of the TIV in a bus.
My engine has 1.7 heads with 2.0 valves, a compression ratio just a smidge tighter then stock (8.6:1 IIRC), Raby cam based off the Web494 grind, and is running on Microsquirt injection. This engine is putting down 127 at the wheels of my 914, according to a dyno run a few years ago - but there have been changes since in exhaust and LOTS of tuning. In my car it will run at 80+ all day long with the heads staying around 350 on the freeway pulling hills. On very hot days pulling the long PA hills it will approach 370 after the engine heat soaks, and I have to back it down to somewhat more legal speeds.
Will a bus kill this engine? IIRC the camper special had a good bit less power then my engine, but I don't recall what that combo was - or even if it was a 2056.
The bus needs to stay air cooled, so putting a suby in it is not an option at this time. Corviar is an option, but I want to retain the manual so I'd need the reverse rotation cam for the corvair. And keeping the stock 1700 is an option too.
Zach
VaccaRabite
post Jul 19 2021, 08:53 PM
En Garde!
the engine in the bus right now is the 1700 stock motor. So it has a TIV as stock. I'd need to pull the motor out of the 914, put all the tins on it and put it back in the bus.
I'm considering one of Eric's turnkey fuel injected engines for the 914, so my 2056 would be surplus. It would get setrab aux oil coolers with a fan pack, and a dakota digital head temp for sure in the bus (just like I have in the 914). Depending on the needs of Erics engine, I'd probably just take the Setrab coolers I have out of my 914 with the engine and put them right on to the bus.
And then drive around in my microsquirt fuel injected bus.
@Eric_Shea
Zach
- Lo-Fi Version Time is now: 28th December 2024 - 03:38 AM
