> Adjusting Headlight Door, Tried Pelican thread - no help
Gatornapper
post Jul 20 2021, 08:15 PM
My right headlight door is lined up squarely in its place, but the rear is too low and front too high when in the closed position. It is fine in the open position.
I tried the methods on the Pelican thread here:
http://forums.pelicanparts.com/porsche-914...adjustment.html
This worked for my left door which was a few degrees out of alignment clockwise.
But it is not working for the horizontal alignment problem. Seems there has to be an adjustable screw somewhere that is a stop for the door in the down position like there is when it is in the up position.
Thanks in advance for the advice.
GN
bkrantz
post Jul 21 2021, 07:06 PM
Using the knob will only reset the position temporarily. The next time you cycle the lights opened and closed, they go back to the original mis-fit.
What worked for me is to reset the crank position on the drive spindle. To do that, you have to remove the hard plastic cover and open the rubber cover to expose the crank. You can then loosen the spindle nut enough so the crank can come off the internal splines, and then shift it so the lid is fully closed, and then tighten the spindle nut.
BTW, do this only with the battery disconnected, the headlight fuses pulled, or the headlight relay pulled. The system has enough power to do serious damage to fingers. And don't touch the manual knob during the process, or you will have to start over.
- Lo-Fi Version Time is now: 27th December 2024 - 07:27 PM
