> Adjusting Headlight Door, Tried Pelican thread - no help
Gatornapper
post Jul 20 2021, 08:15 PM
My right headlight door is lined up squarely in its place, but the rear is too low and front too high when in the closed position. It is fine in the open position.
I tried the methods on the Pelican thread here:
http://forums.pelicanparts.com/porsche-914...adjustment.html
This worked for my left door which was a few degrees out of alignment clockwise.
But it is not working for the horizontal alignment problem. Seems there has to be an adjustable screw somewhere that is a stop for the door in the down position like there is when it is in the up position.
Thanks in advance for the advice.
GN
post Jul 21 2021, 07:51 PM
Resident German
http://www.914world.com/specs/headlight_adjustment.php
Gatornapper
post Jul 22 2021, 04:23 PM
SirAndy & bkrantz -
THANK YOU!
I had previously pulled the plastic cover off but saw the rubber covering the gear lever mechanism and stopped there. Didn't know if it came off & didn't want to mess it up trying.
On mine, the right one goes down too far when closed - it is fine when lights are on. So hope I don't have to mess with the 10mm nut and screw.
The link explains it all perfectly.
Will report back when I get it adjusted.
GN
QUOTE(SirAndy @ Jul 21 2021, 07:51 PM) *
- Lo-Fi Version Time is now: 27th December 2024 - 06:35 PM
