GB 2 of 2 Side marker lenses Both L & R $19.99 a set, +LEDs, base clips, screws, seals boots - Closes TODAY !!! |
Mikey914 |
Jul 9 2021, 12:25 AM
The rubber man Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We have been hand casting these for quite some time and they were fairly labor intensive. Your choice either clear or amber.
And when you buy these you will be able add to your cart to the following items at a discount. Set of LED amber "bulbs" Side marker install clips Front turn signal lenses new correct screws for both Side marker seals We are working out the exact pricing but it will be about 40% off the above items. I'll post up some pics on the LEDs installed shortly so you can see how bright they are. So just a +1 and we will send you the discount code As I noted in the title I have another GB going and can combine. It is right here - http://www.914world.com/bbs2/index.php?act...=0#entry2929410 Just a +1 on that thread and we will send you the code if it too. Attached thumbnail(s) |
Mikey914 |
Jul 31 2021, 09:33 AM
Closes today. I will need to send you a code. I'll be checking about 8PM Pacific to send out codes so you can expect shortly after. Also if you have a code use it.
(IMG:style_emoticons/default/beer3.gif) |
Lo-Fi Version | Time is now: 28th June 2024 - 08:40 PM |
