> Restoration Literati914 Build, A clipped car rebuild
Literati914
post Oct 24 2019, 07:56 PM
I've been putting this off, but I guess I should document the restoration build for my latest 914. I finally got the car on my property and even though there no garage (YET) I can go ahead and get some things started. This will be my 3rd 914 and it'll be a bit of a second chance for this car, as it has a front end section that's been grafted on (by PO) because of a previous accident - not to mention the rusted away hell-hole and holes in the floor. The graft actually looks pretty well done and solid, and the other items will be addressed. The car came with it's original engine - a 1.7 that's freshly rebuilt with zero miles on the rebuild (uninstalled). I've also got a 2056cc 'GA' motor that'll probably end up in this car.
The car was originally L21E Tangerine and someone's gone over it with a real crappy red paint. Since my last 914(/6) was L21E Tangerine.. I'm going to paint this one something else, and will be doing all bodywork and paint myself.
This "restoration" will be considered a driver quality effort.. but I don't plan on cutting too many corners either. I plan to do a quality job but it won't be going across the block at Christies either. Lots of parts have already been sourced, but there's always more, right! Here's the BEFORE shots:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.postimg.cc-7222-1571968560.1.jpg)
Literati914
post Aug 10 2021, 09:41 PM
My longs are generally in good condition on this car, but there was a small amount of perforated metal (outer skin) where the two rear firewalls meet the longs on each side, so I’ve been cutting and patching:
Passenger side, before, during and after-
Literati914   Restoration Literati914 Build   Oct 24 2019, 07:56 PM
Literati914   UGLY FLOORS: http://www.914world.com/bbs2/uploads_...   Oct 24 2019, 08:04 PM
PlaysWithCars   You've got your hands full with that one. Alw...   Oct 25 2019, 12:21 AM
Literati914   I've not been doing much of anything to my 914...   Dec 10 2019, 07:31 PM
Literati914   Here's my replacement metal test fit: [img]htt...   Dec 10 2019, 07:34 PM
rjames   Here's my replacement metal test fit: [img]ht...   Dec 12 2019, 11:53 AM
ssuperflyoldguy   Looks like you used galvanized- bravo.   Jan 25 2020, 01:10 AM
KELTY360   Here's my replacement metal test fit: [img]ht...   Jan 25 2020, 10:20 PM
ClayPerrine   When can I come by and see it? I can bring a 914 ...   Dec 11 2019, 10:14 PM
Literati914   When can I come by and see it? I can bring a 914...   Jan 24 2020, 11:59 PM
Literati914   I was able to mess with the 914 a couple days sinc...   Jan 25 2020, 12:08 AM
Literati914   Also, I've removed all of the suspension.. for...   Jan 25 2020, 12:15 AM
Literati914   I busted most of the front suspension apart today....   Jan 25 2020, 09:02 PM
mepstein   Put a torch on the bushy gs until they smoke and t...   Jan 25 2020, 09:09 PM
Literati914   Put a torch on the bushy gs until they smoke .. g...   Jan 25 2020, 10:41 PM
bkrantz   Nice work. Every hour and step is progress.   Jan 26 2020, 10:06 PM
Literati914   OK - made some small progress lately. So the gen...   Mar 19 2020, 08:08 PM
Literati914   I know, I'm honestly terrible with documenting...   Jul 26 2021, 09:15 PM
Literati914   We're obviously in Epoxy primer and.. Got my r...   Jul 26 2021, 09:25 PM
Literati914   Oh yeah, before it got on the rotisserie I had to ...   Jul 26 2021, 09:36 PM
Literati914   ^ frustrating, when I use the forums 'attachme...   Jul 26 2021, 09:39 PM
mb911   ^ frustrating, when I use the forums 'attachm...   Jul 27 2021, 08:40 AM
TargaToy   When in the world do you sleep? In addition to th...   Jul 28 2021, 12:38 PM
Literati914   Thanks, however it’s been two years that this ca...   Jul 28 2021, 02:02 PM
Literati914   My longs are generally in good condition on this c...   Aug 10 2021, 09:41 PM
Literati914   Welded up holes from spot welds and the crack unde...   Aug 10 2021, 09:43 PM
Literati914   ..after phospho acid and primer to the inner layer...   Aug 10 2021, 09:44 PM
Literati914   Now to do the driver’s side:   Aug 10 2021, 09:46 PM
Literati914   ..in process:   Aug 10 2021, 09:50 PM
Literati914   I actually finished up just before dark :sawzall:...   Aug 10 2021, 09:57 PM
Literati914   Driver’s side long repair, done:   Aug 11 2021, 04:00 PM
Literati914   .. here’s a picture showing the reason I broke d...   Aug 11 2021, 07:30 PM
Literati914   AFTER clean up :Qarl:   Aug 11 2021, 07:31 PM
bkrantz   I can't imagine doing the underside work I did...   Aug 11 2021, 07:47 PM
Literati914   Ok so today I removed the rear under side of the t...   Aug 16 2021, 09:06 PM
Literati914   Very Loose clutch tube   Aug 16 2021, 09:13 PM
Literati914   ..both repaired   Aug 16 2021, 09:15 PM
Literati914   Here you can see marks for the cuts I made at the ...   Aug 16 2021, 09:20 PM
Literati914   Here’s a before shot of the PS inner firewall pa...   Aug 24 2021, 07:24 PM
Literati914   http://www.914world.com/bbs2/uploads_offsite/i.pos...   Aug 24 2021, 07:27 PM
Literati914   PS inner repair in process   Aug 24 2021, 07:55 PM
Literati914   ^ frustrating, when I use the forums 'attach...   Aug 24 2021, 08:20 PM
Literati914   The outside passengers firewall panel I made up fr...   Aug 24 2021, 08:47 PM
Literati914   RE: Restoration Literati914 Build   Aug 24 2021, 08:54 PM
Literati914   RE: Restoration Literati914 Build   Aug 24 2021, 08:55 PM
Literati914   RE: Restoration Literati914 Build   Aug 24 2021, 09:03 PM
tygaboy   Nice, nice work! :trophy:   Aug 24 2021, 10:52 PM
Literati914   Received a couple more items from RD, time to fini...   Sep 12 2021, 09:09 AM
Literati914   So next up.. the driver’s side inner. This time ...   Sep 12 2021, 09:17 AM
Literati914   Drivers side inner wall with holes ready to be wel...   Sep 12 2021, 09:23 AM
Literati914   The rear DS wall repair was more complicated, need...   Sep 12 2021, 09:29 AM
Literati914   Here you can see where the original ebrake tubes a...   Sep 12 2021, 09:35 AM
Literati914   …I’ll go back and dress the weld and make thin...   Sep 12 2021, 09:53 AM
Literati914   Ok so I’ve realized that when I retacked the clu...   Sep 12 2021, 10:14 AM
Literati914   …tube released   Sep 12 2021, 10:16 AM
Literati914   .. and cleaned   Sep 12 2021, 10:18 AM
Literati914   And a shot showing the remaining gap that needs fi...   Sep 12 2021, 10:31 AM
Literati914   Fabricated a panel and tacked it in.. in this pic ...   Sep 12 2021, 10:42 AM
Literati914   Spitz called himself helping, but honestly didn’...   Sep 12 2021, 11:23 AM
Literati914   Welds knocked down and lightly primed   Sep 12 2021, 06:27 PM
Literati914   Now to tackle the loose clutch tube bracket midway...   Sep 12 2021, 06:31 PM
Literati914   Bracket realigned and rewelded… I didn’t shoot...   Sep 12 2021, 06:36 PM
Literati914   Closed up, worked down and lightly primed   Sep 12 2021, 06:36 PM
bkrantz   Nice. One step at a time.   Sep 12 2021, 07:17 PM
ClayPerrine   This is amazing work. I so need to come see it in...   Sep 13 2021, 12:09 PM
Literati914   Thanks guys! Clay I look forward to having you...   Sep 13 2021, 03:13 PM
Literati914   I attached the flexible nozzle to a long flexy thi...   Sep 13 2021, 03:19 PM
Literati914   Done   Sep 13 2021, 03:20 PM
Literati914   I’ve got this stuff running out of the longs but...   Sep 13 2021, 03:24 PM
Literati914   Wanted to polish off a bottle .. no, not that kind...   Sep 13 2021, 06:07 PM
Literati914   Does anyone know if there is a reference measureme...   Sep 13 2021, 06:10 PM
ClayPerrine   Does anyone know if there is a reference measurem...   Sep 14 2021, 06:50 AM
Literati914   Yes that makes perfect since, thanks! .   Sep 14 2021, 10:23 AM
Literati914   Rusted through areas of the floor and firewalls ar...   Sep 27 2021, 07:41 PM
Literati914   In process   Sep 27 2021, 07:43 PM
Literati914   .. and completed - I’ve got solid floors again ...   Sep 27 2021, 07:44 PM
mbseto   Good persistence, good looking progress!   Sep 28 2021, 06:54 AM
Literati914   Good persistence, good looking progress! Th...   Sep 28 2021, 07:00 PM
Literati914   Here it is all buttoned up:   Sep 28 2021, 07:01 PM
Literati914   Got a couple small items checked off the list The...   Sep 30 2021, 06:51 PM
Literati914   Installed :   Sep 30 2021, 06:52 PM
Literati914   Next I fabbed up a little support bracket for the ...   Sep 30 2021, 06:54 PM
mb911   Well you did better than I. I forgot all together ...   Sep 30 2021, 06:54 PM
Literati914   .. and got that installed:   Sep 30 2021, 06:56 PM
Literati914   .. then it was on to that pesky PS rear hinge (rea...   Sep 30 2021, 06:58 PM
Literati914   Got it measured out and located properly before we...   Sep 30 2021, 07:00 PM
Literati914   The bigger accomplishment tho, was getting the cor...   Sep 30 2021, 07:05 PM
Literati914   Installed… I reused the DS one so it’s not as ...   Sep 30 2021, 07:07 PM
Literati914   Been wet for a couple days but I was able to get o...   Oct 2 2021, 07:26 PM
Literati914   After..   Oct 2 2021, 07:27 PM
Literati914   .. next I’ll be patching the huge hole in the fr...   Oct 2 2021, 07:30 PM
nivekdodge   I Have the same issue. Im thinking of making a pla...   Oct 2 2021, 07:42 PM
Literati914   I Have the same issue. Im thinking of making a pl...   Oct 2 2021, 08:24 PM
Literati914   Frunk floor replacement panel ready to install.. i...   Oct 3 2021, 06:41 PM
Literati914   .. not my best welds, as I had trouble chasing goo...   Oct 3 2021, 06:43 PM
Literati914   .. the inside side :D , I’ll go back and seem s...   Oct 3 2021, 06:44 PM
Literati914   This next issue is a doozy… this car was in a fr...   Oct 5 2021, 08:04 PM
Literati914   .. it was the same story on the driver's side,...   Oct 8 2021, 08:27 PM
Literati914   I stripped down the back side of my stock heat shi...   Oct 11 2021, 07:03 PM
4 Pages V  1 2 3 > »
18 User(s) are reading this topic (18 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 21st December 2024 - 07:18 PM
