GB 1 of 2 - Fuel injector Rubber holders - NLA now we have them, $8 for a set of 4 All GB's close July 31st |
Mikey914 |
Jul 8 2021, 11:52 PM
The rubber man Group: Members Posts: 12,714 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I have got a few calls for these and as I need them too decided to make them. The choice is to try to reuse the old ones and if you go through a few you can get a set, but they aren't as solid as the originals as they have deformed from pressure, heat and time.
Pictures aren't as pretty as they can be but these fit nice. $8 for a set of 4 on GB small and easy to ship. These are in production and will start shipping beginning of next week, if you are having issues with how firmly your injectors are being held in this is your answer, so who needs a set? As I mentioned we are also done with tooling on another item we have been making, but were hand casting - Side marker lenses both clear and amber. There is another thread that will be going for them. I'll put the link here so you can +1 if you want that deal too. That way shipping can be combined. http://www.914world.com/bbs2/index.php?act...=0#entry2929417 (IMG:style_emoticons/default/beerchug.gif) Attached thumbnail(s) |
SteveL |
Aug 11 2021, 08:32 PM
Senior Member Group: Members Posts: 661 Joined: 7-August 03 From: Andover, MN Member No.: 991 Region Association: None |
You are talking about the larger rubber o-ring seals, correct?
I need a set of both the larger seals and the small lower seals. Also, do you have replacement fuel injector hoses (the short lines from fuel rail to injector? Thanks |
Lo-Fi Version | Time is now: 28th September 2024 - 08:14 PM |
