Replacement Fuel Injectors, Have an injector leaking |
SteveL |
Aug 12 2021, 02:46 PM
Senior Member Group: Members Posts: 663 Joined: 7-August 03 From: Andover, MN Member No.: 991 Region Association: None |
So, I hooked up my brand new HF fuel pressure gauge (thanks for the tip at $19).
Sure enough, starts, runs fine for a minute, starts missing, fuel pressure drops, engine dies as pressure gets under 20lbs. Wait a minute, engine starts back up, repeat cycle. All of a sudden, I see a spray of fuel coming from injector #1. Can't really tell if it is coming from the short hose from fuel rail to injector or the injector seal. I assume that I caused this problem while moving the fuel rail around when hooking up the pressure gauge to the test port. The only way to make it leak is to put everything back, but then there is too much stuff in the way to see where it is leaking. The injectors have been replaced by me in the past, but it has been over 15 years. Should I just bite the bullet and replace all 4? Can I get mine rebuilt (do they replace the hoses?) I found injectors reman'd by Standard Motor Products for $35.79 ea on Rockauto - are these any good, or junk? Thanks |
SteveL |
Aug 12 2021, 05:29 PM
I checked out Mr. Injector, and they currently have a 2-3 week backlog. I ordered the new SMP remans from RockAuto, and will send in my old ones to Mr. Injector to have a backups.
Now to find the kinked hose.... |
Lo-Fi Version | Time is now: 22nd December 2024 - 10:29 PM |
