> Replacement Fuel Injectors, Have an injector leaking
SteveL
post Aug 12 2021, 02:46 PM
So, I hooked up my brand new HF fuel pressure gauge (thanks for the tip at $19).
Sure enough, starts, runs fine for a minute, starts missing, fuel pressure drops, engine dies as pressure gets under 20lbs. Wait a minute, engine starts back up, repeat cycle.
All of a sudden, I see a spray of fuel coming from injector #1. Can't really tell if it is coming from the short hose from fuel rail to injector or the injector seal. I assume that I caused this problem while moving the fuel rail around when hooking up the pressure gauge to the test port. The only way to make it leak is to put everything back, but then there is too much stuff in the way to see where it is leaking.
The injectors have been replaced by me in the past, but it has been over 15 years. Should I just bite the bullet and replace all 4? Can I get mine rebuilt (do they replace the hoses?) I found injectors reman'd by Standard Motor Products for $35.79 ea on Rockauto - are these any good, or junk?
Thanks
SteveL
post Aug 12 2021, 04:56 PM
Mine are green tops, with 0 280 150 112 stamped on the edge. These are in a 1.8 L Jet. Are all green tops for 2.0? Do I have the wrong injectors?
bdstone914
post Aug 15 2021, 07:48 AM
bdstone914
QUOTE(SteveL @ Aug 12 2021, 03:56 PM) *
L jet and D jet injectors use a different electrical connector plug. L jet are either turquose or grey.
I have not ran the number to check if they are correct.
You can not rebuild an injector. They are just cleaned and tested. The hoses can be replaced but if the body is leaking they are junk
@SteveL
SteveL   Replacement Fuel Injectors   Aug 12 2021, 02:46 PM
Craigers17   My engine at the time was a 2.0. Here's every...   Aug 12 2021, 02:58 PM
iankarr   Pressure dropping after start and then recovering ...   Aug 12 2021, 04:11 PM
cary   We're using the FJ67's too. I have 8 arriv...   Aug 12 2021, 04:18 PM
FlacaProductions   I'm running the FJ67s as well.   Aug 12 2021, 04:34 PM
SteveL   Mine are green tops, with 0 280 150 112 stamped on...   Aug 12 2021, 04:56 PM
wonkipop   Mine are green tops, with 0 280 150 112 stamped o...   Aug 13 2021, 03:16 AM
914sgofast2   [quote name='SteveL' post='2937435' date='Aug 12 ...   Aug 13 2021, 08:47 PM
bdstone914   Mine are green tops, with 0 280 150 112 stamped o...   Aug 15 2021, 07:48 AM
wonkipop   [quote name='SteveL' post='2937435' date='Aug 12 ...   Aug 17 2021, 12:00 AM
SteveL   I checked out Mr. Injector, and they currently hav...   Aug 12 2021, 05:29 PM
iankarr   If you haven’t recently moved the fuel tank (and...   Aug 12 2021, 11:41 PM
SteveL   To me, those are closer to a green than a blue :sh...   Aug 14 2021, 08:35 PM
wonkipop   To me, those are closer to a green than a blue :s...   Aug 14 2021, 08:51 PM
Arno914   This holds true for all sorts of injectors: Use it...   Aug 17 2021, 12:20 AM
wonkipop   This holds true for all sorts of injectors: Use i...   Aug 17 2021, 02:29 AM
SteveL   I received the SMP injectors from RockAuto. The b...   Aug 19 2021, 03:23 PM
Craigers17   Hey Steve, Just for a reference, because I notic...   Aug 19 2021, 05:06 PM
SteveL   Hey Steve, Just for a reference, because I noti...   Aug 19 2021, 05:09 PM
Craigers17   Actually, I've since sold the car. I've a...   Aug 19 2021, 05:26 PM
SteveL   I installed one side (2 injectors) to replace the ...   Aug 19 2021, 07:14 PM
ClayPerrine   For those of you running L-Jet on a 1.8, go to FLA...   Aug 19 2021, 09:32 PM
wonkipop   For those of you running L-Jet on a 1.8, go to FL...   Aug 21 2021, 02:56 AM
FlacaProductions   Here are the FJ67's I'm running - 74 2.0 -...   Aug 20 2021, 09:54 AM
17 User(s) are reading this topic (17 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 22nd December 2024 - 10:45 PM
