> Replacement Fuel Injectors, Have an injector leaking
SteveL
post Aug 12 2021, 02:46 PM
So, I hooked up my brand new HF fuel pressure gauge (thanks for the tip at $19).
Sure enough, starts, runs fine for a minute, starts missing, fuel pressure drops, engine dies as pressure gets under 20lbs. Wait a minute, engine starts back up, repeat cycle.
All of a sudden, I see a spray of fuel coming from injector #1. Can't really tell if it is coming from the short hose from fuel rail to injector or the injector seal. I assume that I caused this problem while moving the fuel rail around when hooking up the pressure gauge to the test port. The only way to make it leak is to put everything back, but then there is too much stuff in the way to see where it is leaking.
The injectors have been replaced by me in the past, but it has been over 15 years. Should I just bite the bullet and replace all 4? Can I get mine rebuilt (do they replace the hoses?) I found injectors reman'd by Standard Motor Products for $35.79 ea on Rockauto - are these any good, or junk?
Thanks
Arno914
post Aug 17 2021, 12:20 AM
Region Association: Germany
This holds true for all sorts of injectors: Use it or loose it. (IMG:style_emoticons/default/biggrin.gif)
wonkipop
post Aug 17 2021, 02:29 AM
QUOTE(Arno914 @ Aug 17 2021, 12:20 AM) *
which i am now fargen well doin mate - and grinning doen it - these injectors are gettin a good work out. short delay at present while i fix my clagged front wheel bearings, another use it or lose it moment (IMG:style_emoticons/default/beerchug.gif)
SteveL   Replacement Fuel Injectors   Aug 12 2021, 02:46 PM
Craigers17   My engine at the time was a 2.0. Here's every...   Aug 12 2021, 02:58 PM
iankarr   Pressure dropping after start and then recovering ...   Aug 12 2021, 04:11 PM
cary   We're using the FJ67's too. I have 8 arriv...   Aug 12 2021, 04:18 PM
FlacaProductions   I'm running the FJ67s as well.   Aug 12 2021, 04:34 PM
SteveL   Mine are green tops, with 0 280 150 112 stamped on...   Aug 12 2021, 04:56 PM
wonkipop   Mine are green tops, with 0 280 150 112 stamped o...   Aug 13 2021, 03:16 AM
914sgofast2   [quote name='SteveL' post='2937435' date='Aug 12 ...   Aug 13 2021, 08:47 PM
bdstone914   Mine are green tops, with 0 280 150 112 stamped o...   Aug 15 2021, 07:48 AM
wonkipop   [quote name='SteveL' post='2937435' date='Aug 12 ...   Aug 17 2021, 12:00 AM
SteveL   I checked out Mr. Injector, and they currently hav...   Aug 12 2021, 05:29 PM
iankarr   If you haven’t recently moved the fuel tank (and...   Aug 12 2021, 11:41 PM
SteveL   To me, those are closer to a green than a blue :sh...   Aug 14 2021, 08:35 PM
wonkipop   To me, those are closer to a green than a blue :s...   Aug 14 2021, 08:51 PM
Arno914   This holds true for all sorts of injectors: Use it...   Aug 17 2021, 12:20 AM
wonkipop   This holds true for all sorts of injectors: Use i...   Aug 17 2021, 02:29 AM
SteveL   I received the SMP injectors from RockAuto. The b...   Aug 19 2021, 03:23 PM
Craigers17   Hey Steve, Just for a reference, because I notic...   Aug 19 2021, 05:06 PM
SteveL   Hey Steve, Just for a reference, because I noti...   Aug 19 2021, 05:09 PM
Craigers17   Actually, I've since sold the car. I've a...   Aug 19 2021, 05:26 PM
SteveL   I installed one side (2 injectors) to replace the ...   Aug 19 2021, 07:14 PM
ClayPerrine   For those of you running L-Jet on a 1.8, go to FLA...   Aug 19 2021, 09:32 PM
wonkipop   For those of you running L-Jet on a 1.8, go to FL...   Aug 21 2021, 02:56 AM
FlacaProductions   Here are the FJ67's I'm running - 74 2.0 -...   Aug 20 2021, 09:54 AM
- Lo-Fi Version Time is now: 22nd December 2024 - 10:09 PM
