Where to buy..., ...some items the typical go-to places don't have |
Speedo |
Sep 2 2021, 02:50 PM
Senior Member Group: Members Posts: 547 Joined: 7-November 06 From: Boulder Member No.: 7,170 Region Association: Rocky Mountains |
I don't want to try to make these. Car is a 70 six. First up under the PET for pedals, cables and levers.
I need the little collar that supports the rod for the cold start up by the gas pedal #914 424 219 00 Next the "intermediate piece" that is the guts of the shifter U-joint #914 424 212 00 Now the two seals for the oil tank 901 107 679 10 and 901 107 696 40. And these last two...do they seal the hole from the inside of the engine compartment, or are they between the oil cooler and the inner fender. |
914Sixer |
Sep 3 2021, 06:03 PM
914 Guru Group: Members Posts: 8,986 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Check with 914 Rubber on support rod. They made a throttle kit. Check Porsche Classic on the oil tank seals since they are early 911 numbers. Shift rod block is an unknown.
Lo-Fi Version | Time is now: 21st September 2024 - 07:05 PM |
