Halfnelson |
Member ![]() ![]() Group: Members Posts: 55 Joined: 31-July 17 From: Cornwall Member No.: 21,303 Region Association: England ![]() |
Anyone have experience with these injectors? I have them fitted to my recently acquired 73 1.7 with standard Djet.
My car is currently running very rich / flooding and the injectors are heading to a local specialist for testing as we suspect one of them is sticking. The alternative is they are the wrong spec for the car. Anyone else run them? https://www.fiveomotorsport.com/hose-type-e...ro-asian-sport/ They are the 380cc type. Thanks, Chris ![]() |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
No, they are compatible--they spray a metered amount of fuel just fine.
It's just that it's the wrong amount for a 1.7 engine. They can probably be made to inject the right amount for a 1.7, but it will require work to the rest of the FI. It's a fine difference between "compatible" and "correct", but it's there. Especially if you are selling the parts. --DD |
Halfnelson |
No, they are compatible--they spray a metered amount of fuel just fine. It's just that it's the wrong amount for a 1.7 engine. They can probably be made to inject the right amount for a 1.7, but it will require work to the rest of the FI. It's a fine difference between "compatible" and "correct", but it's there. Especially if you are selling the parts. --DD Thanks Dave - would this be a complex way of doing things or would it be simple ie tweaking fuel pressure? I would need to order replacement injectors from the US so that would take a while so if tweaking is relatively straightforward that would be an option for sure. What is the correct metered about a 1.7 injector should deliver? |
sholman5 |
Kraut burner ![]() ![]() Group: Members Posts: 189 Joined: 11-September 16 From: Ormond beach, Fl. Member No.: 20,391 Region Association: South East States ![]() ![]() |
No, they are compatible--they spray a metered amount of fuel just fine. It's just that it's the wrong amount for a 1.7 engine. They can probably be made to inject the right amount for a 1.7, but it will require work to the rest of the FI. It's a fine difference between "compatible" and "correct", but it's there. Especially if you are selling the parts. --DD Thanks Dave - would this be a complex way of doing things or would it be simple ie tweaking fuel pressure? I would need to order replacement injectors from the US so that would take a while so if tweaking is relatively straightforward that would be an option for sure. What is the correct metered about a 1.7 injector should deliver? ![]() |
Lo-Fi Version | Time is now: 25th June 2024 - 07:39 PM |
