Fuel pump wiring in a 6 conversion - non relay board, Is a relay needed? |
nditiz1 |
Sep 8 2021, 01:12 PM
Senior Member Group: Members Posts: 1,202 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
So I'm not using a relay board in my 6 conversion. I have cut the 14 point harness where it branches to the trunk, so maybe just 2 ft off the end. I left the starter wire the full length. In hindsight I should have left the tach and idiot light wires just as long, but it's OK, enough to butt splice. Anyway, there are 2 red wires(switched 12 volts) I was planning on 1 for the ECU and have the other kick on the fuel pump. Is there any reason I need to run a relay for the fuel pump?
Steve |
Sep 8 2021, 02:26 PM
914 Guru Group: Members Posts: 5,680 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
The ignition switch is pretty wimpy and Porsche always ran a relay for the pump. I would add a relay or worse case use fuse 8, which is already on a relay.
Lo-Fi Version | Time is now: 18th September 2024 - 07:21 PM |
