Where to buy..., ...some items the typical go-to places don't have |
Speedo |
Sep 2 2021, 02:50 PM
Senior Member Group: Members Posts: 529 Joined: 7-November 06 From: Boulder Member No.: 7,170 Region Association: Rocky Mountains |
I don't want to try to make these. Car is a 70 six. First up under the PET for pedals, cables and levers.
I need the little collar that supports the rod for the cold start up by the gas pedal #914 424 219 00 Next the "intermediate piece" that is the guts of the shifter U-joint #914 424 212 00 Now the two seals for the oil tank 901 107 679 10 and 901 107 696 40. And these last two...do they seal the hole from the inside of the engine compartment, or are they between the oil cooler and the inner fender. |
Speedo |
Sep 9 2021, 01:21 PM
There may be some miscommunication I think this is what you want - https://914rubber.com/manual-throttle-actuator-kit-1 If your pedal assembly is a true 6 you will have the tab welded to the accelerator on the assembly. We do make these in sets so I can't break it apart without loosing a set. If you need we can weld one up (you send us yours as a core) For $25 and plate it. That should be the only difference on the assembly. Pretty sure I have a complete set of bushings I can sell you too. Not listed (as a complete set) but can get you what you need. (IMG:style_emoticons/default/biggrin.gif) Also have a few other pieces you need. Mark I have an original six, so I don't need the kit. I need the one small bushing that the throttle start shaft slides through, up by the accelerator pedal. I have already fabricated the u-joint for the shift coupler, and the two seals for the oil tank. If I cannot find this bushing separately I will fab it. |
Lo-Fi Version | Time is now: 20th June 2024 - 05:30 AM |
