Fuel pump wiring in a 6 conversion - non relay board, Is a relay needed? |
nditiz1 |
Sep 8 2021, 01:12 PM
Senior Member Group: Members Posts: 1,202 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
So I'm not using a relay board in my 6 conversion. I have cut the 14 point harness where it branches to the trunk, so maybe just 2 ft off the end. I left the starter wire the full length. In hindsight I should have left the tach and idiot light wires just as long, but it's OK, enough to butt splice. Anyway, there are 2 red wires(switched 12 volts) I was planning on 1 for the ECU and have the other kick on the fuel pump. Is there any reason I need to run a relay for the fuel pump?
Spoke |
Sep 9 2021, 08:12 PM
Jerry Group: Members Posts: 7,051 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I was planning on 1 for the ECU and have the other kick on the fuel pump. Is there any reason I need to run a relay for the fuel pump? Will the ECU turn on/off the fuel pump like the OEM ECU does? It's usually not good to have the fuel pump come on with the ignition since if in an accident or a fuel line ruptures the fuel pump will continue to operate. |
mepstein |
Sep 10 2021, 05:22 AM
914-6 GT in waiting Group: Members Posts: 19,504 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I was planning on 1 for the ECU and have the other kick on the fuel pump. Is there any reason I need to run a relay for the fuel pump? Will the ECU turn on/off the fuel pump like the OEM ECU does? It's usually not good to have the fuel pump come on with the ignition since if in an accident or a fuel line ruptures the fuel pump will continue to operate. That happened to a member here on a freshly done six conversion. Engine caught fire, fuel pump continued to run. |
Lo-Fi Version | Time is now: 18th September 2024 - 07:11 PM |
