Boxster console |
Boxster console |
partwerks |
Sep 22 2021, 07:58 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Anyone have any pictures of what has been done for a console that works with the 6 speed Boxster setup?
If I use the Boxster console, looks like I would have to somehow patch in where the electricals were, and the handbrake. To get it to set back far enough, I would probably have to cut about 3" off the bottom of the center backpad, but then may not be able to open the console door, or take a section out of the length of the console. How easy is it to mend it back together and make it look like something? Also, will the factory rear sway bar, fit if using the 6 speed boxster trans? |
tygaboy |
Sep 24 2021, 11:45 PM
914 Guru Group: Members Posts: 5,427 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
I have a custom tunnel frame and console but the same idea would work: all you need is a shifter stand that puts the lever where you'd like it. In my case, it's up a bunch and fairly close to the steering wheel, in terms of fore/aft.
This is a Numeric shifter with their cables, which in this case are stock length. They offer shorter or longer, or at least they did. I opted to run the cables exposed, running on top of the console. IMO, it fits the vibe of my build. Hope this helps. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 21st September 2024 - 06:54 PM |
