mmichalik |
MikeM ![]() ![]() ![]() Group: Members Posts: 708 Joined: 27-January 16 From: Valley Center, CA Member No.: 19,600 Region Association: Southern California ![]() ![]() |
The car was sent out to my mechanic to shore everything up about 3 months ago. I've been working on it for about 5 years now and I wanted a second set of eyes on somethings while also finishing up some stuff that I'm not comfortable doing.
The car had sat for about 10 years before I got it and was a mouse motel for most of that time. There was a lot of electrical work that needed to be done, among other things. Here's a high level list of what they did: 1) installed the tangerine racing carb linkage 2) installed the tangerine racing shift linkage 3) Put new boots on the tie rod ends 4) Tightened up all the suspension (front and rear) 5) Got the rear brakes installed and working (PMB rebuilds) 6) fixed all the chewed up wiring on the main harness 7) installed the new ignition and alternator harnesses 8) installed all the rebuilt gauges and got them working 9) rewired all the dash lights. 10) rewired all of the front and rear lights 11) took special time to re-wrap all of the harnesses 12) setup and configured the carbs 13) got the motor running, fixed any of the minor oil leaks, etc.. 14) put the restored fuchs on the car (with continental 195x65 15's) 15) lots of various other miscellaneous stuff The install of the interior, upper and lower dash and the front and rear glass will start this weekend. After that is done, we'll start doing the shake down driving and dial her in, adjust the ride height, etc.... I naively thought I could do it in 2 years when it all started. Attached thumbnail(s) ![]() |
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,858 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
Your car looks beautiful and soon enough will be putting a huge smile on your face as you are cruising the roads. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 26th June 2024 - 10:43 AM |
