High Beam & Turn Signal Problem Still not sorted, Urgent Help on high beam issue and other problems |
MFejsa |
Sep 26 2021, 12:19 PM
Newbie Group: Members Posts: 40 Joined: 25-April 20 From: Saudi Arabia Member No.: 24,178 Region Association: None |
Hi All,
See my latest report. Urgent help needed as I can not get registration till these last issues are resolved. 1. I’ve jumped the red/yellow wire on headlight relay and can not get power to the white wire and can not get high beams to work 2. I can get power to the red wire going to the headlight relay and can get power to the yellow wire at the relay and the low beams work but when I flick the light switch to activate the high beam nothing happens and no power to fuses #1 & 2. 3. When I pull the light switch to try and get high beams to work, the horn sounds momentarily and when I indicate left or right the horn sounds sometimes. I think its grounding somewhere in the steering column? 4. Also, I managed to get the hazard light to work yesterday morning and today when I tried it out again, Its not working. I checked all the wiring against wiring diagram for the hazard light switch and correct wires are in the correct connectors Please help, anyone. Cheers Michael |
jrmdir |
Sep 28 2021, 01:04 PM
Member Group: Members Posts: 224 Joined: 13-May 21 From: Central Ohio Member No.: 25,544 Region Association: Upper MidWest |
Quote: [DO YOU NEED A JUMPER BETWEEN 30 LUG AND 56?]
Yes! - See this thread, Post # 6 - http://forums.pelicanparts.com/porsche-914...ight-relay.html Sounds like your problem may be solved? Ron |
Lo-Fi Version | Time is now: 24th September 2024 - 01:14 PM |
