Boxster console |
Boxster console |
partwerks |
Sep 22 2021, 07:58 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Anyone have any pictures of what has been done for a console that works with the 6 speed Boxster setup?
If I use the Boxster console, looks like I would have to somehow patch in where the electricals were, and the handbrake. To get it to set back far enough, I would probably have to cut about 3" off the bottom of the center backpad, but then may not be able to open the console door, or take a section out of the length of the console. How easy is it to mend it back together and make it look like something? Also, will the factory rear sway bar, fit if using the 6 speed boxster trans? |
tygaboy |
Sep 29 2021, 02:21 PM
914 Guru Group: Members Posts: 5,427 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
Lyle - Here's the factory muffler bracket that bolts to the rear of your Boxster S, G86-20 trans. Your guy could use this and make a cross brace that bolts to those slotted holes at the top and supports a muffler on each end.
Attached image(s) |
partwerks |
Sep 29 2021, 03:37 PM
Lyle - Here's the factory muffler bracket that bolts to the rear of your Boxster S, G86-20 trans. Your guy could use this and make a cross brace that bolts to those slotted holes at the top and supports a muffler on each end. I presume that is made out of aluminum? |
Lo-Fi Version | Time is now: 21st September 2024 - 06:56 PM |
