partwerks |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 ![]() |
Anyone have any pictures of what has been done for a console that works with the 6 speed Boxster setup?
If I use the Boxster console, looks like I would have to somehow patch in where the electricals were, and the handbrake. To get it to set back far enough, I would probably have to cut about 3" off the bottom of the center backpad, but then may not be able to open the console door, or take a section out of the length of the console. How easy is it to mend it back together and make it look like something? Also, will the factory rear sway bar, fit if using the 6 speed boxster trans? ![]() ![]() ![]() ![]() ![]() ![]() |
The Double S |
Member ![]() ![]() Group: Members Posts: 93 Joined: 8-October 19 From: Upland, CA Member No.: 23,545 Region Association: Southern California ![]() |
Clay it looks like you have an aftermarket short shifter? How do you like that?
Anyone else have an opinion on stock vs. short shift? |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,547 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Clay it looks like you have an aftermarket short shifter? How do you like that? Anyone else have an opinion on stock vs. short shift? I bought the short shift kit, and when I put it it in, it was way too close to the floor, and way too stiff to shift. So I took it apart and welded on a 914 shifter handle. Then I put on the custom 6 speed knob I made. Once I get a console in there, it will look somewhat stock. Clay |
Lo-Fi Version | Time is now: 20th June 2024 - 05:42 AM |
