partwerks |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 ![]() |
Unless I'm wrong again, didn't the 75-76 have a wiper delay, and relay that mounted on the DS cowl brace?
If so, is there a diagram to get it wired back up, since my X mechanic messed that up also. I'm not so sure I don't have a aftermarket switch with no down position for it currently. |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,918 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
All SWF wiper switches had 3rd position. 3rd position is obtained by breaking off plastic tang. HOWEVER the switch HAS to have 5 wire pins to make intermittent wiper work. IF you use the 6 wire switch you can have both intermittent and electric pump.
Intermittent wipers were not standard. They had to be ordered. You can update at any time. Check Classic Threads for information on wiring. |
Lo-Fi Version | Time is now: 24th June 2024 - 07:14 AM |
