> KB 96 (2056) fly cut valve notch, 8 notches: 4 intake and 4 exhaust ...Pics and instruction
rfinegan
post Oct 4 2021, 04:01 PM
After the engine fail on my 2056 the investigation began measuring the piston the valve clearance. I tried the clay/ Playdoe method and the results were not as good as I would like. So i set up the failed Number 1 piston with the smiley (IMG:style_emoticons/default/smile.gif)
I set up the head from the other side without the bent valve and used the rocker shaft spring (just a light weight spring I had handy)to push down the valve till contact was made with the piston and the cam lobe was starting open the intake. At about 10 degrees on the degree wheel the closest reading was 0.080. ( this was in the small indentation made by the valve failure)
I tilted the mill head to align with the valve guide and set the piston in the v blocks and used my 123 blocks to center the piston pin.
I indexed the center of the intake valve with a pencil to set the Y axis on my Bridgeport.
Centered on the mark, I now had to find the correct x axis. Since I already had the mark from the valve on the piston, I set the fly cutter .100 more than the diameter of the 44mm valve. The marked put the piston top was indexed and moved my X axis in to touch the previous valve mark. I then moved my X axis .050 inch and confirmed my zero to the cutter.
I moved my Knee (set to zero) .050 inch to make the first cut. The piston crown of the KB measured at .220 ( for a min .170 thickness). This feels like a safe depth and puts my clearance at .130.
I will repeat the process on the 2 valves notches with no "kiss' marks by marking up the piston tops with marker and using the valves to get the reference mark by hand
Dion
post Oct 4 2021, 04:11 PM
RN
I wish I could fully understand what you just explained! It’s fascinating. Keep it coming.
Enjoying the education. (IMG:style_emoticons/default/beerchug.gif)
rfinegan   KB 96 (2056) fly cut valve notch   Oct 4 2021, 04:01 PM
rfinegan   mill angle   Oct 4 2021, 04:02 PM
rfinegan   piston set up and fly cut to .050 @[url=http...   Oct 4 2021, 04:10 PM
Dion   I wish I could fully understand what you just expl...   Oct 4 2021, 04:11 PM
rfinegan   @Dion i better go back and read it again...My br...   Oct 4 2021, 04:31 PM
rfinegan   here is a pick of the play doe   Oct 4 2021, 04:37 PM
rfinegan   exhaust valve clearance   Oct 4 2021, 04:38 PM
Dion   @rfinegan Nope no problem with your writing. Itâ€...   Oct 4 2021, 05:02 PM
rfinegan   set up pic   Oct 4 2021, 05:23 PM
Jamie   set up pic The arc of the fly cut is a curve, ...   Oct 4 2021, 05:33 PM
PatMc   set up pic The arc of the fly cut is a curve,...   Oct 4 2021, 06:58 PM
rfinegan   I see the problem now, I should have locked the Kn...   Oct 5 2021, 03:46 AM
rfinegan   I made a valve notch cutter out of an Old AMC inta...   Oct 5 2021, 09:57 AM
rfinegan   Practice cut look in good Now I just need to fin...   Oct 5 2021, 10:01 AM
barefoot   Practice cut look in good Now I just need to fin...   Oct 5 2021, 10:12 AM
rfinegan   @Barefoot problems with useing the heads: 1) 2 o...   Oct 5 2021, 11:04 AM
mmichalik   I'm absolutely fascinated by all of this and w...   Oct 5 2021, 10:20 AM
rfinegan   I am going to walk through this process One MORE T...   Oct 5 2021, 01:30 PM
rfinegan   I just got off the phone with UEM the manufacture ...   Oct 5 2021, 02:04 PM
rfinegan   center punched locators on piston tops   Oct 5 2021, 02:06 PM
rfinegan   Piston set up on valve center to Centerline of Qui...   Oct 5 2021, 02:07 PM
rfinegan   Cutter and finish cut to .050 pocket   Oct 5 2021, 02:08 PM
rfinegan   Now you too, have the information and skills to Va...   Oct 5 2021, 02:10 PM
PatMc   Now you too, have the information and skills to V...   Oct 5 2021, 05:10 PM
ChrisFoley   I made a fixture to hold pistons at the correct an...   Oct 6 2021, 06:09 AM
rfinegan   Final Clearance measured on # 1 cylinder . ( small...   Oct 6 2021, 07:51 AM
ChrisFoley   How much larger is the eyebrow radius than the val...   Oct 6 2021, 09:40 AM
rfinegan   Radius is .050 larger. Or added .100 to the diame...   Oct 6 2021, 10:38 AM
rfinegan   I did a valve to piston check on Cylinder 2 both i...   Oct 6 2021, 02:25 PM
930cabman   Are your valve springs up to the task?   Oct 6 2021, 05:23 PM
rfinegan   Yep, Brand new double spring/HD springs retainers...   Oct 6 2021, 08:16 PM
rfinegan   Raby Cam   Oct 7 2021, 03:53 AM
rfinegan   Ha haaaa...   Oct 7 2021, 04:56 AM
930cabman   Thanks for reporting with this good information. C...   Oct 7 2021, 06:46 AM
rfinegan   @[url=http://www.914world.com/bbs2/index.php?showu...   Oct 7 2021, 07:19 AM
rfinegan   One good things about grinding/sanding the valve n...   Oct 7 2021, 04:10 PM
maf914   rfinegan, Thanks for posting your engine build an...   Oct 7 2021, 04:41 PM
rfinegan   @maf914 Thank you for the encouragement. There w...   Oct 7 2021, 05:04 PM
rfinegan   FROM THE WEB: According to WebCam the minimum cle...   Oct 8 2021, 11:42 AM
rfinegan   I am not convinced my clearances were an issue. Bu...   Oct 8 2021, 01:38 PM
- Lo-Fi Version Time is now: 9th January 2025 - 05:45 PM
