rfinegan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 974 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region ![]() ![]() |
After the engine fail on my 2056 the investigation began measuring the piston the valve clearance. I tried the clay/ Playdoe method and the results were not as good as I would like. So i set up the failed Number 1 piston with the smiley (IMG:style_emoticons/default/smile.gif)
![]() I set up the head from the other side without the bent valve and used the rocker shaft spring (just a light weight spring I had handy)to push down the valve till contact was made with the piston and the cam lobe was starting open the intake. At about 10 degrees on the degree wheel the closest reading was 0.080. ( this was in the small indentation made by the valve failure) I tilted the mill head to align with the valve guide and set the piston in the v blocks and used my 123 blocks to center the piston pin. I indexed the center of the intake valve with a pencil to set the Y axis on my Bridgeport. Centered on the mark, I now had to find the correct x axis. Since I already had the mark from the valve on the piston, I set the fly cutter .100 more than the diameter of the 44mm valve. The marked put the piston top was indexed and moved my X axis in to touch the previous valve mark. I then moved my X axis .050 inch and confirmed my zero to the cutter. I moved my Knee (set to zero) .050 inch to make the first cut. The piston crown of the KB measured at .220 ( for a min .170 thickness). This feels like a safe depth and puts my clearance at .130. I will repeat the process on the 2 valves notches with no "kiss' marks by marking up the piston tops with marker and using the valves to get the reference mark by hand |
rfinegan |
Practice cut look in good
![]() Now I just need to find the centerline of the valve guild (transfer at TDC with head and piston mock up) and a pencil down the valve guide. Then plunge cut with the Quill . Just like a valve opening or using the head as a guide to cut out the notches witha spinning valve. TO bad its the wrong stem and do not fit the heads With a bit of luck the previous notch may cut out? NO holding my breath. but 50 buck will get a new piston on the way if needed. I have to order the push rods any how' (IMG:style_emoticons/default/confused24.gif) |
barefoot |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,282 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States ![]() ![]() |
Practice cut look in good Now I just need to find the centerline of the valve guild (transfer at TDC with head and piston mock up) and a pencil down the valve guide. Then plunge cut with the Quill . Just like a valve opening or using the head as a guide to cut out the notches witha spinning valve. TO bad its the wrong stem and do not fit the heads With a bit of luck the previous notch may cut out? NO holding my breath. but 50 buck will get a new piston on the way if needed. I have to order the push rods any how' (IMG:style_emoticons/default/confused24.gif) Or you could just re-assemble motor and use the actual valve guide in the head and an electric drill to rotate your abrasive coated valve, would be quick & accurate. Just insure no swarf gets down to the rings |
Lo-Fi Version | Time is now: 26th June 2024 - 06:42 AM |
