Fuel lines leaking, Two steps forward, one step back |
914Next |
Oct 5 2021, 12:50 PM
Senior Member Group: Members Posts: 702 Joined: 28-July 14 From: Ephraim Wisconsin Member No.: 17,695 Region Association: Upper MidWest |
Well, as some of you know I had three leaking injectors when I went to pull the car out of storage after a couple of months. Two sealed up after running the car a bit and one I had to change out for new injector. Of course I was elated that I had solved that problem BUT....as I returned from a test drive I saw gas leaking onto the driveway in another spot. Seems that now a fuel line is leaking. Appears to be a cloth line leaking just after exiting the firewall (near the doughnuts as seen in the pic below).
I believe that the are the lines that I should be changing out anyway? I'm fairly certain that most of thessee lines are original. Posting a couple of pics. Looking now for recommendations.....change out for all stainless steel lines? Are stainless replacing those in the engine compartment as well as forward to the gas tank? Any diagrams showing the ones that I need to consider replacing? Also what level of DIY is this. I'm fairly handy but not a mechanic. Can I do this myself? If so would I need a lift in order to do it? Appreciate the input. Steve |
mepstein |
Oct 5 2021, 01:10 PM
914-6 GT in waiting Group: Members Posts: 19,507 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Steve - I would order the kit from Tangerine Racing. The install is very easy without the engine in the car. I am told it is doable with the engine in. I would call Chris Foley and ask him for tips and suggestions. He knows his product and these cars. But I would get the stainless kit with fuel hose and clamps no matter what.
I have seen 914’s, 911’s and a VW beetle, burnt to the ground, because of fuel leaks. It isn’t pretty and it’s easy to mitigate. You will have to drain the tank and remove it to hook up the fuel hose from the tunnel to the tank. It’s not hard, just time consuming but it does give you a chance to clean and inspect that area. If you have a friend with a lift, it makes everything easier. If you pay a mechanic to do it, it’s still money well spent - in my opinion. |
914Next |
Oct 5 2021, 01:17 PM
Steve - I would order the kit from Tangerine Racing. The install is very easy without the engine in the car. I am told it is doable with the engine in. I would call Chris Foley and ask him for tips and suggestions. He knows his product and these cars. But I would get the stainless kit with fuel hose and clamps no matter what. I have seen 914’s, 911’s and a VW beetle, burnt to the ground, because of fuel leaks. It isn’t pretty and it’s easy to mitigate. You will have to drain the tank and remove it to hook up the fuel hose from the tunnel to the tank. It’s not hard, just time consuming but it does give you a chance to clean and inspect that area. If you have a friend with a lift, it makes everything easier. If you pay a mechanic to do it, it’s still money well spent - in my opinion. Thanks Mark. The problem is a bit more challenging since I recently moved the car to northern Wisconsin and I’m not sure there is any mechanic (that I would trust) with anymore expertise than myself in getting this done. I’d love to try to do it myself if I can. I’ll call Chris. Thanks. |
Lo-Fi Version | Time is now: 21st September 2024 - 06:59 PM |
