sixaddict |
Senior Member ![]() ![]() ![]() Group: Members Posts: 812 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States ![]() ![]() |
Steering wheel number is
914 347 805 11 Is it for a 4 or 6 Thanks |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,579 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
All of the Porsche steering wheels will fit on a 914, including 911, 944, 928, etc...
They are all splined the same. You can use that wheel, and the only way you can tell the difference would be to take the horn hub off and look at it. Clay |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,331 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
All of the Porsche steering wheels will fit on a 914, including 911, 944, 928, etc... They are all splined the same. You can use that wheel, and the only way you can tell the difference would be to take the horn hub off and look at it. Clay All the splines are the same but the chamfer on the shaft of a vw column is meant to fit a vw Huber wheel and Porsche to Porsche. So while it works, it’s not what the Porsche engineers intended for a good reason. The fit is not optimal. |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:37 PM |
