KB 96 (2056) fly cut valve notch, 8 notches: 4 intake and 4 exhaust ...Pics and instruction |
rfinegan |
Oct 4 2021, 04:01 PM
Senior Member Group: Members Posts: 1,016 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
After the engine fail on my 2056 the investigation began measuring the piston the valve clearance. I tried the clay/ Playdoe method and the results were not as good as I would like. So i set up the failed Number 1 piston with the smiley (IMG:style_emoticons/default/smile.gif)
I set up the head from the other side without the bent valve and used the rocker shaft spring (just a light weight spring I had handy)to push down the valve till contact was made with the piston and the cam lobe was starting open the intake. At about 10 degrees on the degree wheel the closest reading was 0.080. ( this was in the small indentation made by the valve failure) I tilted the mill head to align with the valve guide and set the piston in the v blocks and used my 123 blocks to center the piston pin. I indexed the center of the intake valve with a pencil to set the Y axis on my Bridgeport. Centered on the mark, I now had to find the correct x axis. Since I already had the mark from the valve on the piston, I set the fly cutter .100 more than the diameter of the 44mm valve. The marked put the piston top was indexed and moved my X axis in to touch the previous valve mark. I then moved my X axis .050 inch and confirmed my zero to the cutter. I moved my Knee (set to zero) .050 inch to make the first cut. The piston crown of the KB measured at .220 ( for a min .170 thickness). This feels like a safe depth and puts my clearance at .130. I will repeat the process on the 2 valves notches with no "kiss' marks by marking up the piston tops with marker and using the valves to get the reference mark by hand |
maf914 |
Oct 7 2021, 04:41 PM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
rfinegan,
Thanks for posting your engine build and these latest piston valve notch details. While I understand what you are doing I have nowhere near the skill to do detail work like this, nor the equipment to do it. I really would like to see you put this thing back together and say that it is running great. One thing I was wondering is that when you do the valve notch do you then polish the piston top and valve notch to eliminate possible sharp edges that might cause hot spot pre-ignition? That just some stuff I remember from engine build magazine articles. (IMG:style_emoticons/default/laugh.gif) |
Lo-Fi Version | Time is now: 27th September 2024 - 01:03 PM |
