sixaddict |
Senior Member ![]() ![]() ![]() Group: Members Posts: 812 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States ![]() ![]() |
Steering wheel number is
914 347 805 11 Is it for a 4 or 6 Thanks |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,580 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
All of the Porsche steering wheels will fit on a 914, including 911, 944, 928, etc...
They are all splined the same. You can use that wheel, and the only way you can tell the difference would be to take the horn hub off and look at it. Clay |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,331 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
All of the Porsche steering wheels will fit on a 914, including 911, 944, 928, etc... They are all splined the same. You can use that wheel, and the only way you can tell the difference would be to take the horn hub off and look at it. Clay All the splines are the same but the chamfer on the shaft of a vw column is meant to fit a vw Huber wheel and Porsche to Porsche. So while it works, it’s not what the Porsche engineers intended for a good reason. The fit is not optimal. |
ClayPerrine |
All of the Porsche steering wheels will fit on a 914, including 911, 944, 928, etc... They are all splined the same. You can use that wheel, and the only way you can tell the difference would be to take the horn hub off and look at it. Clay All the splines are the same but the chamfer on the shaft of a vw column is meant to fit a vw Huber wheel and Porsche to Porsche. So while it works, it’s not what the Porsche engineers intended for a good reason. The fit is not optimal. Where did you get this information? I have never heard of this, and I talked with Ed Mayo about it. Clay |
mepstein |
All of the Porsche steering wheels will fit on a 914, including 911, 944, 928, etc... They are all splined the same. You can use that wheel, and the only way you can tell the difference would be to take the horn hub off and look at it. Clay All the splines are the same but the chamfer on the shaft of a vw column is meant to fit a vw Huber wheel and Porsche to Porsche. So while it works, it’s not what the Porsche engineers intended for a good reason. The fit is not optimal. Where did you get this information? I have never heard of this, and I talked with Ed Mayo about it. Clay Yea, Ed has made some incorrect statements about steering wheels. Just look at it yourself. I believe Betty's car is later so you can remove the steering wheel and see the difference for yourself. The 10 & 11 on the end of the part number make it easy to tell whether its Porsche or VW. The 1973 RS used a 914-6 wheel and not a '73 914 wheel because the six wheel has the proper Porsche hub. |
ClayPerrine |
All of the Porsche steering wheels will fit on a 914, including 911, 944, 928, etc... They are all splined the same. You can use that wheel, and the only way you can tell the difference would be to take the horn hub off and look at it. Clay All the splines are the same but the chamfer on the shaft of a vw column is meant to fit a vw Huber wheel and Porsche to Porsche. So while it works, it’s not what the Porsche engineers intended for a good reason. The fit is not optimal. Where did you get this information? I have never heard of this, and I talked with Ed Mayo about it. Clay Yea, Ed has made some incorrect statements about steering wheels. Just look at it yourself. I believe Betty's car is later so you can remove the steering wheel and see the difference for yourself. The 10 & 11 on the end of the part number make it easy to tell whether its Porsche or VW. The 1973 RS used a 914-6 wheel and not a '73 914 wheel because the six wheel has the proper Porsche hub. Do you have some documentation from Porsche that shows this? I am not saying you are wrong, I just want to see some proof. Clay |
mepstein |
All of the Porsche steering wheels will fit on a 914, including 911, 944, 928, etc... They are all splined the same. You can use that wheel, and the only way you can tell the difference would be to take the horn hub off and look at it. Clay All the splines are the same but the chamfer on the shaft of a vw column is meant to fit a vw Huber wheel and Porsche to Porsche. So while it works, it’s not what the Porsche engineers intended for a good reason. The fit is not optimal. Where did you get this information? I have never heard of this, and I talked with Ed Mayo about it. Clay Yea, Ed has made some incorrect statements about steering wheels. Just look at it yourself. I believe Betty's car is later so you can remove the steering wheel and see the difference for yourself. The 10 & 11 on the end of the part number make it easy to tell whether its Porsche or VW. The 1973 RS used a 914-6 wheel and not a '73 914 wheel because the six wheel has the proper Porsche hub. Do you have some documentation from Porsche that shows this? I am not saying you are wrong, I just want to see some proof. Clay I’ve already proved it to myself. I’m just giving you sure me info. Believe it or not. |
sixaddict |
Here is picture of the back side.
Hope this helps debate ![]() ![]() quote name='mepstein' date='Oct 7 2021, 03:04 PM' post='2951066'] [quote name='ClayPerrine' post='2951036' date='Oct 7 2021, 05:22 PM'] [quote name='mepstein' post='2951033' date='Oct 7 2021, 03:51 PM'] [quote name='ClayPerrine' post='2951023' date='Oct 7 2021, 03:21 PM'] [quote name='mepstein' post='2951010' date='Oct 7 2021, 01:41 PM'] [quote name='ClayPerrine' post='2950954' date='Oct 7 2021, 12:00 PM'] All of the Porsche steering wheels will fit on a 914, including 911, 944, 928, etc... They are all splined the same. You can use that wheel, and the only way you can tell the difference would be to take the horn hub off and look at it. Clay [/quote] All the splines are the same but the chamfer on the shaft of a vw column is meant to fit a vw Huber wheel and Porsche to Porsche. So while it works, it’s not what the Porsche engineers intended for a good reason. The fit is not optimal. [/quote] Where did you get this information? I have never heard of this, and I talked with Ed Mayo about it. Clay [/quote] Yea, Ed has made some incorrect statements about steering wheels. Just look at it yourself. I believe Betty's car is later so you can remove the steering wheel and see the difference for yourself. The 10 & 11 on the end of the part number make it easy to tell whether its Porsche or VW. The 1973 RS used a 914-6 wheel and not a '73 914 wheel because the six wheel has the proper Porsche hub. [/quote] Do you have some documentation from Porsche that shows this? I am not saying you are wrong, I just want to see some proof. Clay [/quote] I’ve already proved it to myself. I’m just giving you sure me info. Believe it or not. [/quote] |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:10 PM |
