Aux. Heater Blower Power-1975 1.8, Electrical Issues |
ballsyfacts914 |
Oct 3 2021, 04:23 PM
Member Group: Members Posts: 82 Joined: 28-August 19 From: East Bay Region-SF Bay Area Member No.: 23,413 Region Association: Northern California |
Hi All,
I haven't posted in awhile, after having some work done on the 914, I have been enjoying the heck out of the good weather driving around. I also have been make other small adjustments and finding the parts that have been missing...like the auxiliary heater blower. I installed my nice used heater blower and it wouldn't turn on. After double checking my connections and that everything was in the right place, I tested the wires from the harness and there was no power. I will admit now that electrical work is my weak point so I am still learning. I deep-dived and found a few things amiss, see photos below. The first is of the relay board, I know several of the circular plug in relays(?) are missing. There is also a rogue yellow wire connected to a rogue blue wire, haven't seen anything that tells me why that was done. The second photo is of the harness and everything looks close but I think a few things may be wrong, namely wire colors not matching. The other thing, the wires that I used to hook into the blower split off from the main harness and don't seem to be connected to the relay board. I would love any advice on what I need part wise, if I should replace anything, and/or what I need to redo wire wise. The second photo will be posted, it was too big to add here. Thanks in advance, really appreciate this community! |
NARP74 |
Oct 8 2021, 04:47 PM
Senior Member Group: Members Posts: 1,084 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
Take a look behind your speaker covers in the corners. When I pulled mine to blow dust out, I saw gaping holes in the tubes going into the front trunk. heat was not making it where it was supposed to go. Good luck and keep posting. My front blower does not work so that is on my list.
Actually everything is on my list! |
Lo-Fi Version | Time is now: 24th June 2024 - 11:51 PM |
