Speedometer wire |
Speedometer wire |
partwerks |
Oct 8 2021, 08:13 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
The speedo worked when last parked, but now nothing works, and found a green/white wire in that area unhooked.
All the rest of my gauges are working correctly. So my assumption would be, it would plug in there somewhere, but not sure where. It's marked signal on the top, and + - on the bottom. Looks like a couple more places on the bottom to hook, and one more on the top to plug in. |
Chris914n6 |
Oct 9 2021, 10:56 AM
Jackstands are my life. Group: Members Posts: 3,390 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Aftermarket gauge. You will need to look for a wiring diagram specific to it.
Looks like your speed is the 2 grey wires marked 'sig' w/g wire iirc is high beam. You are also missing 'ground' to the gauge. |
partwerks |
Oct 9 2021, 06:09 PM
Aftermarket gauge. You will need to look for a wiring diagram specific to it. Looks like your speed is the 2 grey wires marked 'sig' w/g wire iirc is high beam. You are also missing 'ground' to the gauge. So, I need two wires hooked up, maybe three? How do I find the wiring diagram for it? |
Lo-Fi Version | Time is now: 24th September 2024 - 01:15 PM |
