Speedometer wire |
Speedometer wire |
partwerks |
Oct 8 2021, 08:13 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
The speedo worked when last parked, but now nothing works, and found a green/white wire in that area unhooked.
All the rest of my gauges are working correctly. So my assumption would be, it would plug in there somewhere, but not sure where. It's marked signal on the top, and + - on the bottom. Looks like a couple more places on the bottom to hook, and one more on the top to plug in. |
Chris914n6 |
Oct 9 2021, 09:16 PM
Jackstands are my life. Group: Members Posts: 3,390 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Connecting a ground wire 'brown' should make the gauge work.
Being aftermarket probably doesn't have the high beam lite the factory gauge does. Assuming it's VDO. Is it VSS or GPS signal? |
partwerks |
Oct 9 2021, 09:31 PM
Connecting a ground wire 'brown' should make the gauge work. Being aftermarket probably doesn't have the high beam lite the factory gauge does. Assuming it's VDO. Is it VSS or GPS signal? Actually was working when I took it in for reworking the previous mechanics problems, and some upgrades. He probably mistakenly removed something. Took a box of old previous owners wiring the size of a 12" square cube. If I had to guess, I would say VSS. Seems like there was some gadget to convert the signal? The high beam works, but doesn't go hand in hand with this one. |
Lo-Fi Version | Time is now: 24th September 2024 - 01:15 PM |
